I need Help in servo control
i’m trying to make a scanning mechanism using a set of two servo motors, but i want the pattern of the scan to be like this :
------------------->--------------------o
I------------------>--------------------^
starting from (I) till (O) but every line it shift to the upper line without returning to the start position again
i tried using (for) loop including an (if) condition with (break) and (goto) but it didn’ work.
I'd love to help but I haven't the slightest idea what you mean, sorry.
Post your code. Use [ code ] tags.
This looks like a 'raster' scan, like old TVs used to do. That should be easy.
Something like this pseudo code
move servo A to the opposite end
move servo B up a little
repeat as needed
...R
i'm trying to make a scanning mechanism using a set of two servo motors, but i want the pattern of the scan to be like this :
Look at the "sweep" servo example in the arduino IDE examples. At the end of each pan sweep, add an incremental movement to the tilt servo.
