i need help in timer and keeping signal on
How to keep signal as On
function:
Sensor sense object and Sensorvalue<100
Motor move backward for 10 sec (continue moving although Sensor did not sense object and go more than 100)
I am stuck can help me or hint to how to start
int motorright= 2;
int motorleft= 3;
int Sensor = A1;
float Sensorvalue;
unsigned time;
  pinMode(motorright,OUTPUT);
  pinMode(motorleft,OUTPUT);
  pinMode(Sensor,INPUT);
int Sensorvalue = analogRead(Sensor);
if (Sensorvalue <=100) // there is object
   digitalwrite(motorright, HIGH);
   digitalwrite(motorleft, HIGH);
Easy. Don't turn it Off.
int Sensorvalue  = 0;
float Sensorvalue;
That code will not compile. Quit wasting our time posting code that can't be compiled.
PaulS:
float Sensorvalue;
opps I edited out that part now is compile
You have pins called 'motorleft' and 'motorright'. What combination of signals makes the motor go 'backward'? What combination of signals makes the motor stop?
