i need help in using classes in arduino
i want to know how to use classes in arduino
*hint : i have read the how to make a library tutorial
but i wanna ask can i just declare the class in the predefinition area as we do with functions or declare it anywhere else
or i have to make new files as the library
and if i have to make new files can you give me clear steps how to make and where to put theses files
Normally the class definition is in a *.h file and the functions are in a *.ccp file.
In the Arduino IDE is a drop-down menu on the upper-right. You can use that to create new files.
A simple class is a few functions, and a few variables. The variables are often private.
Write the class in the *.h file and the function in the *.cpp file.
Check the EEPROM class, very simple : https//github.com/arduino/Arduino/tree/master/libraries/EEPROM
Do you see this: EEPROMClass EEPROM;
and this: extern EEPROMClass EEPROM;
That is because the class is being declared. Normally that would be done in the sketch.
More advanced is the LiquidCrystal class with private functions and private variables : https://github.com/arduino/Arduino/tree/master/libraries/LiquidCrystal
i dont want to make a library
i want to use classes as function by declaration in the same arduino code file (is this possible)
Yes, use that code I showed you (the EEPROM and CrystalLibrary *.h and *.cpp files) and put it all in the same Arduino file.
First the definition, and all the functions below that.
I think the definition of the class must be on top, before the setup() and loop().
After some time, you want to put those in a seperate *.h and *.cpp files anyway ![]()
When you add those *.h and *.cpp files to your project (using the drop down menu), you don't have a library. They will be just files in your project.
Peter_n:
Yes, you are correct. If setup or or loop do not use the class its fine to place it underneath, just before the functions that do.
C/C++ compiles from top to bottom, so the class must be declared before its functions are defined externally, and before the code that uses the actual class.
