I need help making a code on Arduino 1.8.5
#include <SD.h> // need to include the SD library
#define SD_ChipSelectPin 4 //connect pin 4 of arduino to cs pin of sd card
#include <TMRpcm.h> //Arduino library for asynchronous playback of PCM/WAV files
#include <SPI.h> //  need to include the SPI library
TMRpcm tmrpcm; // create an object for use in this sketch
int temp=1;
int pp=5;
int next=6;
int prev=7;
 pinMode(pp,INPUT_PULLUP);
 pinMode(next,INPUT_PULLUP);
 pinMode(prev,INPUT_PULLUP);
 tmrpcm.speakerPin = 9; //5,6,11 or 46 on Mega, 9 on Uno, Nano, etc
 if (!SD.begin(SD_ChipSelectPin)) // returns 1 if the card is present
  Serial.println("SD fail");
  return;
 tmrpcm.setVolume(5); //
 tmrpcm.play("song1.wav"); //the sound file "song" will play each time the arduino powers up, or is reset
                          //try to provide the file name with extension
  while(digitalRead(pp)==0 || digitalRead(next)==0 || digitalRead(prev)==0)
    if(digitalRead(pp)==0)
      tmrpcm.pause();
      while(digitalRead(pp)==0);
      delay(200);
    else if(digitalRead(next)==0)
      if(temp<4)//temp should be lesser than no. of songs
      temp=temp+1;
      while(digitalRead(next)==0);
      delay(200);
      song();
    else if(digitalRead(prev)==0)
      if(temp>1)
      temp=temp-1;
      while(digitalRead(prev)==0);
      delay(200);
      song();
void song (void)
  if(temp==1)
  else if(temp==2)
    tmrpcm.play("song2.wav");
  else if(temp==3)
    tmrpcm.play("song3.wav");
  else if(temp==4)`Preformatted text`
    tmrpcm.play("song4.wav");
I used a tutorial on youtube to help me but it keeps saying deprecated conversion from string constant to 'char*' for pretty much everything... I am beginner but when I started this it seemed much easier. The youtube video I followed is this -> How to Make a Music Player using Arduino? - YouTube ... Please someone help me.
  • List item
Please read the sticky at the top- post the error messages.
I've never used the TrPcm library, but I am guessing that the error is on lines like this:
I am just guessing, but "song4.wav" is a constant and the function is expecting a pointer to a char array.
Try
char mySong4[10] = "song4.wav";
tmrpcm.play(mySong4);
thank you so much. I'll give that a try and see what happens.
