I am tryng to write a code for my project which will use two IR sensors.
The sensors are going to be placed next to each other.. for the sake of argument, lets call the sensors A and B. The sensors will be placed at an enterace of a room, and will detect a person coming in or going out of a room. By using two sensors i will be able to tell the direction of movement.
When a person come into the room, sensor A first detects it, then sensor B
when a person leaves the room, Sensor B first detects and then sensor B.
However, if just one sensor detects a movement and the second one wont, that means it is not a complete movement.
In the code i have tried to make it as, if A detects then Arduino should wait 5 sec to see B will detect. If B detects, that mean coming In..
If B first detects, Arduino should wait for A for 5 sec to see if A will detect. If A does, it mean going out..
I have tired using if statement, within an if statement..
I have tired using if statement, within while statement..
But both didnt work..
I dont know how to implement the "waiting for input for 5 sec"
I need help
//Blink without Delay skeleton
//4 examples demonstrated
//LED wiring options
//Depending which way your LEDs are wired, uncomment the next line.
//#define PlusEqualsON
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON LOW
#define ledOFF HIGH
#endif
//switch wiring options
//Depending which way your switches are wired, uncomment the next line.
#define PushEqualsLOW
#ifdef PushEqualsLOW
//pushing the switch makes pin LOW
#define Pushed LOW
#define Released HIGH
#else
//pushing the switch makes pin HIGH
#define Pushed HIGH
#define Released LOW
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL; //100ms
unsigned long ledOnTime = 5*1000UL; //5 seconds
byte laststartSwitchState = HIGH;
byte buttonState = HIGH;
byte counter = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch = 3; //pushed = LOW
digitalWrite(13,ledOFF);
pinMode(13, OUTPUT);
digitalWrite(12,ledOFF);
pinMode(12, OUTPUT);
digitalWrite(11,ledOFF);
pinMode(11, OUTPUT);
digitalWrite(10,ledOFF);
pinMode(10, OUTPUT);
pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
pinMode(testSwitch, INPUT_PULLUP); //pushed = LOW
} // >>>>>>>>>>>>>> E N D O F s e t u p ( ) <<<<<<<<<<<<<<<<<
//save the current time
currentMillis = millis();
//************************************* E x a m p l e 1
//toggle pin 13 every 200mS
//has 200ms or more gone by?
if (currentMillis - pin13Millis >= 200UL)
//code here runs every 200ms
//get ready for next iteration
pin13Millis = pin13Millis + 200UL;
//toggle pin 13
digitalWrite(13,!digitalRead(13));
//************************************* E x a m p l e 2
//at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
//could be used as a powerup reset signal
if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
//code here runs for 3 seconds after power up, then stops
digitalWrite(12,ledON);
//disable further pin 12 control
flag12 = false;
//************************************* E x a m p l e 3
//if testSwitch is pushed and released
//pin 11 LED goes ON for 5 seconds, then goes OFF
buttonState = digitalRead(testSwitch);
//are we are allowed to check the switch and is it pressed?
if(flag11 == true && buttonState == Pushed)
//enable timing of LED on pin 11
flag11 = false; //false --> timing is enabled
//turn LED ON
digitalWrite(11,ledON);
//record the time LED turned ON
pin11Millis = currentMillis;
//are we allowed and is it time to control pin 11
if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
//if enabled, code here runs after ledOnTime ms goes by
//allow switch press detection again
flag11 = true; //true --> switch monitoring is enabled
//************************************* E x a m p l e 4
//is it time to check the switches?
//in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
if (currentMillis - SwitchMillis >= debounceMillis)
//code here runs every debounceMillis ms
//get ready for the next iteration
SwitchMillis += debounceMillis;
//go and check the switches
checkSwitches();
//put other non-blocking stuff here
} // >>>>>>>>>>>>>> E N D O F l o o p ( ) <<<<<<<<<<<<<<<<<
// F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
//re-usable for all the switches
boolean thisState;
//************************************* E x a m p l e Push ON push OFF (toggle)
//check if this switch has changed state
thisState = digitalRead(startSwitch);
if (thisState != laststartSwitchState)
//update the switch state
laststartSwitchState = thisState;
//this switch position has changed so do some stuff
//"HIGH condition code"
//switch went from LOW to HIGH
if(thisState == HIGH)
//Do some HIGH switch stuff here
//"LOW condition code"
//switch went from HIGH to LOW
//Do some LOW switch stuff here
digitalWrite(10, !digitalRead(10));
//print number of pushes
counter++;
Serial.println(counter);
} //END of startSwitch code
//similar code for other switches goes here
} //END of checkSwitches()
// E N D O F C O D E
How will you know which sensor detected movement first? Do you plan to write blocking code that will ignore sensor A after it gets triggered? I hope not, because what would happen then if sensor B got triggered first?
IR sensors to count people in a room rarely work, because a person could trip one sensor, and then back out. Or, two people walking side by side could trip them both, and be counted as one. Then, one person leaves, and your count of people in the room is then wrong.
On the other hand, roughly 14 bazillion people have tried this. Surely someone posted some code somewhere, so you can see all the mistakes and erroneous assumptions made.
