I need help regarding soap and water dispenser using the same output hose
I need some help regarding a project on an automated soap and water dispenser using arduino. I intended on having soap and water dispensed from the same output with an interval of 20seconds after the soap have been dispensed first
I need help on how to allow flow of liquid simultaneously in a valve using arduino
pope001:
Then you need to provide us with a great deal more information.
Links to datasheets for the valves would be useful.
And a description of the logic that the Arduino is expected to apply.
…R
You need a valve that can serve both inlets at the same time, not only switch between both.
I have worked on a similar project. It was coffee vending machine and I have to provide different liquid materials through a single opening.
So, it depends more on your mechanical structure than Arduino coding. You should design T shaped structure and add automatic Flow Valves. Control these valves using Arduino.
