I need help to configure the digital gates
I want to used the digital gates 0 and 1.
This gates normally is used for serial comunication (TX - RX).
I have used the command “ pinMode( 0, INPUT)” and “ pinMode( 1, INPUT)”, but after in this gates I have always one tension ( 4,9 V ).
My question is : Is possible to used these digital gates ( gate 0 and gate 1 ) and what mode is necessary to setting arduino for to used these gates ?
Thanks for help me :)
They're "pins", not "gates".
Have you disconnected these pins from the FTDI chip?
yes that will be what happens, the input floats. To use the pins as an output use:- pinMode( 2, OUTPUT); in the setup();
and then do digitalWrite(2,LOW); to put a low voltage on the pin and digitalWrite(2,HIGH); to put a high voltage on the pin
As mentioned do not use pins 0 and 1 until you know what you are doing.
Thanks for help Groove and Grumpy_Mike
No, for the moment I not disconnected these pins from the FTDI chip.
what mode is necessary to disconnected these pins from the FTDI chip?
This operation is software o hardware ? :)
Hardware - I think there's a series resistor to be removed. Which board are you using?
Hardware - I think there’s a series resistor to be removed.
I thought you could do a Serial.end(), then use the pins?
http://arduino.cc/en/Serial/End
I using the Arduino 2009, after that you give me this information, I gone to see the elettric schematic.
I see is necesary to remove R8 and R9 (1k ohm) but for the moment, I don't want to make hardware changes at Arduino
Thanks very much Groove
Thanks cr0sh
Now I want to try the command that you told at me ;D
I tried the command serial.end() but it don't work :'(
I think the only solution for to use the Pin 0 and 1 is to remove the R8 and R9 ;)
What do you need all the pins for?
Maybe a shift register or port expander is what you need to give you more pins?
Mowcius
Hi Mowcius,
I want to make one toy for soft air.
For the moment, I used one LCD and this to use 6 Digital Pin.
I want to use one keyboard at 16 keys and this to use 8 Digital Pin.
I don't know if is possible to use one keyboard with 4 digital Pin and 4 analogic Pin.
I ask any person if to know one exemple for keyboard ?? :D
So you don't need to use pins 0 and 1.
Use shift registers to scan your keyboard. See:- http://www.arduino.cc/en/Tutorial/ShiftOut
