I need help to implement a timer
Hey. I have a project in which I check the posture of a person, with a Accelerometer(MPU6050). When the y value (see void GetAngle ()) is between 110 and 90 degrees, the person has a good posture. Everything outside of it is a bad posture. Now I have designed it so that the tool first checks whether the person has a correct or incorrect posture and then sends a message (see case: CHECK), When the person has a Bad posture (y >= 110 || y <= 70) the program switches to case: COUNTDOWN. Now I want to implement a timer in the case COUNTDOWN, that if the person still has a wrong posture after 2 minutes, then the program switches to the case: MESSAGE. How can I implement this timer? I also want to stop the loop when a 0 comes in via the bluetooth. This does not work yet. Thanks in advance for your help.
Below is the full program.
#include <SoftwareSerial.h>
#include <Wire.h>
#include <math.h>
SoftwareSerial BT(0, 1); // RX, TX-pin
int BluetoothData = 0; // BT init state
const int MPU_addr = 0x68;
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
int minVal = 265;
int maxVal = 402;
int StartMillis;
bool StartSign = false;
double x;
double y;
double z;
int c;
enum state { CHECK, COUNTDOWN, MESSAGE };
state current_state;
unsigned long countdownMs;
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);
  Wire.write(0);
  Wire.endTransmission(true);
  current_state = CHECK;
void GetAngle()
  Wire.write(0x3B);
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr, 14, true);
  AcX = Wire.read() << 8 | Wire.read();
  AcY = Wire.read() << 8 | Wire.read();
  AcZ = Wire.read() << 8 | Wire.read();
  int xAng = map(AcX, minVal, maxVal, -90, 90);
  int yAng = map(AcY, minVal, maxVal, -90, 90);
  int zAng = map(AcZ, minVal, maxVal, -90, 90);
  x = RAD_TO_DEG * (atan2(-yAng, -zAng) + PI); // Rad to degrees
  y = RAD_TO_DEG * (atan2(-xAng, -zAng) + PI);
  z = RAD_TO_DEG * (atan2(-yAng, -xAng) + PI);
  while (1)
    if (Serial.available())
      c = Serial.read();
      switch (c)
        case ('1'):
          StartSign = true;
          Serial.println("program start");
        case ('0'):
          StartSign = false;
          Serial.println("program stopped");
      if (!Serial.available())
        while (StartSign == true)
          GetAngle();
          switch (current_state)
            case CHECK:
              if (y >= 110 || y <= 70)                              // Wrong posture
                countdownMs = millis();
                current_state = COUNTDOWN;
                Serial.println("Bad posture");
              else                                                  // Good posture
                // do nothing;
                Serial.println("Good posture");
            case COUNTDOWN:
              if ((y >= 110 || y <= 70))                           // Still a wrong posture
                current_state = MESSAGE;
            case MESSAGE:
let's say you have a
unsigned long alarm_time =  0L ;
  if (bad_posture()) {
      if(alarm_time == 0)
         alarm_time = millis() + 120000; //  wake me up after 2 minutes.
     // we-re back to good posture, set alarm time back to 0
     alarm_time = 0;
  // now just check if alarm_time is expired
  if (alarm_time < millis() && alarm_time > 0) ring_the_alarm();
You write your own ring_the_alarm() and boolean bad_posture()
I would recommend that you use millis(). It would be something like
//2 minutes = 120 seconds = 120000 ms
unsigned long interval = 120000;
unsigned long time_now = 0;
   //where you want the timer
if(incorrect_posture )
//start the timer
   Serial.println("warning 1");
   time_now = millis();
   //now check if it exceeds interval
    if(millis() >time_now + interval){
           Serial.println("warning 2");
else//reset timer posture has been corrected
else{
//other code
This is not supposed to be a solution, just a pointer in the right direction. Incase you need/want to consult, feel free to PM me
A much simpler form:
unsigned long alarm_time = millis() + 120000;
    // while posture is good postpone the alarm with two minutes.
    if (good_posture()) alarm_time = millis() + 120*1000;
    if (alarm_time < millis()) ring_the_alarm();
When i grow up i wanna write answers like this (:
blimpyway:
     if(alarm_time == 0)
    alarm_time = 0;
Thanks Blimpyway your solution worked!
