I need help using a button to switch LEDs from "Twinkle" to "Knight Rider"
I'm new to using Arduino and I had a project idea that needed 10 LEDs to twinkle randomly but when you push a button (or flip a switch) they flash like the knight rider car. I have both the codes for the twinkle and the knight rider but I don't know how to integrate them together and a button into this. For all I know it might not even be possible. Any help would be greatly appreciated because I'm truly lost. I looked on google and it must be too specific of a request to have it on there. Thank you for your help!
Here's the twinkle circuit:
* randomly flickering LEDs
int ledPin[] = {
 2, 3, 4, 5, 6, 7, 8, 9, 10, 11};              // pwm pins only
int ledState[5];                 // last state of each led
long randNumber;
 for (int i=0; i<=11; i++){      // set each led pin as an output
   pinMode(ledPin[i], OUTPUT);
 randomSeed(analogRead(0));     // seed the rnd generator with noise from unused pin
 for (int i=0; i<=11; i++){      // init each led with a random value
   ledState[i] = random(20, 201);
void loop(){
 for (int i=0; i<=11; i++){                  // for each led:
   analogWrite(ledPin[i], ledState[i]);     // set the pwm value of that pin determined previously
   randNumber = random(-40, 41);            // generate new random number and add that to the current value
   ledState[i] += randNumber;               // that range can be tweaked to change the intensity of the flickering
   if (ledState[i] > 200) {                 // clamp the limits of the pwm values so it remains within
     ledState[i] = 200;                     // a pleasing range as well as the pwm range
   if (ledState[i] < 10) {
     ledState[i] = 10;
 delay(100);    // the delay between changes
And here is the Knight Rider Circuit:
#define LED1 2
#define LED2 3
#define LED3 4
#define LED4 5
#define LED5 6
#define LED6 7
#define LED7 8
#define LED8 9
#define LED9 10
#define LED10 11
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
pinMode(LED6, OUTPUT);
pinMode(LED7, OUTPUT);
pinMode(LED8, OUTPUT);
pinMode(LED9, OUTPUT);
pinMode(LED10, OUTPUT);
digitalWrite(LED1, HIGH);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
digitalWrite(LED4, LOW);
digitalWrite(LED5, LOW);
digitalWrite(LED6, LOW);
digitalWrite(LED7, LOW);
digitalWrite(LED8, LOW);
digitalWrite(LED9, LOW);
digitalWrite(LED10, LOW);
delay(300);
digitalWrite(LED1, LOW);
digitalWrite(LED2, HIGH);
delay(300);
digitalWrite(LED3, HIGH);
delay(300);
digitalWrite(LED4, HIGH);
delay(300);
digitalWrite(LED5, HIGH);
delay(300);
digitalWrite(LED6, HIGH);
delay(300);
digitalWrite(LED7, HIGH);
delay(300);
digitalWrite(LED8, HIGH);
delay(300);
digitalWrite(LED9, HIGH);
delay(300);
digitalWrite(LED10, HIGH);
delay(300);
Thank you for any and all help you can give!
This is how to merge code
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
Then simply do a digital read on your switch pin and use an if statement looking at the result to call the loop1 or loop2 function.
