I need help using a load cell
This is the load cell that I am using Amazon.com and I am also using a HX771 amplifier. I am also using this buzzer as my effector Amazon.com
What I am trying to do is to get it to sense the force of my iphone and then when it senses that the force is removed it sends a signal to a buzzer that will emit a sound. The problem that I am running into is that I am not fully sure how to code using the load cell. I looked around on google and youtube and figured out how the load cell works but almost all of the tutorials are just showing how to get the load cell to measure something and display it on an lcd screen. I went and downloaded all of the things that they show using in their videos and I took and example project and cut it up into what I think I only need.
   HX711_ADC
   Arduino library for HX711 24-Bit Analog-to-Digital Converter for Weight Scales
   Olav Kallhovd sept2017
   Settling time (number of samples) and data filtering can be adjusted in the config.h file
   For calibration and storing the calibration value in eeprom, see example file "Calibration.ino"
   The update() function checks for new data and starts the next conversion. In order to acheive maximum effective
   sample rate, update() should be called at least as often as the HX711 sample rate; >10Hz@10SPS, >80Hz@80SPS.
   If you have other time consuming code running (i.e. a graphical LCD), consider calling update() from an interrupt routine,
   see example file "Read_1x_load_cell_interrupt_driven.ino".
   This is an example sketch on how to use this library
#include <HX711_ADC.h>
#include <EEPROM.h>
//pins:
const int HX711_dout = 4; //mcu > HX711 dout pin
const int HX711_sck = 5; //mcu > HX711 sck pin
int buzzer = 8;
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
const int calVal_eepromAdress = 0;
unsigned long t = 0;
  Serial.begin(57600); delay(10);
  LoadCell.begin();
  float calibrationValue; // calibration value (see example file "Calibration.ino")
  calibrationValue = 696.0; // uncomment this if you want to set the calibration value in the sketch
#if defined(ESP8266)|| defined(ESP32)
  //EEPROM.begin(512); // uncomment this if you use ESP8266/ESP32 and want to fetch the calibration value from eeprom
#endif
  //EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch the calibration value from eeprom
  unsigned long stabilizingtime = 2000; // preciscion right after power-up can be improved by adding a few seconds of stabilizing time
  boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
  LoadCell.start(stabilizingtime, _tare);
  static boolean newDataReady = 0;
  const int serialPrintInterval = 0; //increase value to slow down serial print activity
  // check if last tare operation is complete:
  if (() < 100) {
    tone(buzzer, 1000); // tone() is the main function to use with a buzzer, it takes 2 or 3 parameteres (buzzer pin, sound frequency, duration)
 tone(buzzer, 2000); // You can also use noTone() to stop the sound it takes 1 parametere which is the buzzer pin
The problem that I'm running into is not knowing what words to use for the load cell in the if statement. I specifically am looking at the line,
if (() < 100) {
I need to know what to put after the first parenthesis and before the open and closed parentheses.
If someone could link a tutorial or explain to me how to get this code to work that would be great
Have you looked at the HX711 library example sketches?
Here's fixed code.
#include <EEPROM.h>
//pins:
int buzzer = 8;
  LoadCell.begin();
#endif
  if (LoadCell.update()) newDataReady = true;
  if (newDataReady) {
    if (millis() > t + serialPrintInterval) {
     float i = LoadCell.getData();
   //  Serial.print("Load_cell output val: ");
   //  Serial.println(i);
    if (i < 100) {
    tone(buzzer, 1000, 500);
      newDataReady = 0;
      t = millis();
