i need help with a error
#include <RFID.h>
  • edited by Velleman / Patrick De Coninck
  • Read a card using a mfrc522 reader on your SPI interface
  • Pin layout should be as follows (on Arduino Uno - Velleman VMA100):
  • MOSI: Pin 11 / ICSP-4
  • MISO: Pin 12 / ICSP-1
  • SCK: Pin 13 / ISCP-3
  • SS/SDA (MSS on Velleman VMA405) : Pin 10
  • RST: Pin 9
  • VCC: 3,3V (DO NOT USE 5V, VMA405 WILL BE DAMAGED IF YOU DO SO)
  • GND: GND on Arduino UNO / Velleman VMA100
  • IRQ: not used
#include <SPI.h>
#include <RFID.h>
#define SS_PIN 10
#define RST_PIN 9
RFID rfid(SS_PIN,RST_PIN);
int power = 7;
int led = 8;
int serNum[5];
  • This integer should be the code of Your Mifare card / tag
    int cards[][5] = {{117,222,140,171,140}};
bool access = false;
void setup(){
SPI.begin();
rfid.init();
  • define VMA100 (UNO) pins 7 & 8 as outputs and put them LOW
    pinMode(led, OUTPUT);
    pinMode (power,OUTPUT);
    digitalWrite(led, LOW);
    digitalWrite (power,LOW);
void loop(){
if(rfid.isCard()){
    if(rfid.readCardSerial()){
        Serial.print(rfid.serNum[0]);
        Serial.print(" ");
        Serial.print(rfid.serNum[1]);
        Serial.print(" ");
        Serial.print(rfid.serNum[2]);
        Serial.print(" ");
        Serial.print(rfid.serNum[3]);
        Serial.print(" ");
        Serial.print(rfid.serNum[4]);
        Serial.println("");
        for(int x = 0; x < sizeof(cards); x++){
          for(int i = 0; i < sizeof(rfid.serNum); i++ ){
              if(rfid.serNum[i] != cards[x][i]) {
                  access = false;
                  access = true;
          if(access) break;
   if(access){
       Serial.println("Welcome Velleman ");
  • Valid card : Switch ON the LED for 1000 ms (1 second)
    digitalWrite(led, HIGH);
  • Valid card : Switch ON the POWER PIN for 2000 ms (2 seconds)), the POWER PIN can activate for example a relais, controlling a doorlock)
    digitalWrite(power, HIGH);
    delay(2000);
    digitalWrite(power, LOW);
    access = false;
  • NON-Valid card : switch ON and OFF the LED twice for 0,5 seconds
    Serial.println("Not allowed!");
    rfid.halt();
Welcome to the forum
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Using code tags prevents the forum software from interpreting parts of your code as HTML commands
You do not say what the error message is
Please post the full error message here in code tags
> avrdude: stk500_recv(): programmer is not responding
You can edit your posts :point_down: down here by clicking on the :pencil2: icon. Then select your text and put it in code tags <|> which are in the toolbar here :point_up_2:
Wrong ^^^
Probably wrong too ^^^
Start with basics sizeof operator - cppreference.com
It is not the sketch that is causing that error, it is the connection between the Arduino board and the PC
  • Which Arduino board are you using ?
  • When you plug the Arduino into the PC is it recognised and does a new COM port get created ?
  • Have you got that COM port selected in the IDE ?
  • Have you got the correct board selected in the IDE ?
  • Are you sure that the USB lead that you are using is a data cable and not just a charging cable with no data lines ?
    *Have you tried a different USB cable ?
I use arduino uno r3 and my port say com6
Den ons 24 aug. 2022 11:01UKHeliBob via Arduino Forum <notifications@arduino.discoursemail.com> skrev:
Could you please fix the first post as politely asked a few times... do your part to keep the forum tiddy if you expect help from this community
➜ edit your post, select the code part and press the </> icon in the tool bar to mark it as code. (also make sure you indented the code in the IDE before copying, that's done by pressing ctrlT on a PC or cmdT on a Mac)
Bad USB connection? Were you able to upload other sketches to this board in the past?
