i need help with arduino --------> Wifly --------> Mysql please !!
hello friends, I need your help to create a code to send from my Arduino board THROUGH Wifly data on two sensors, temperature and humidity, then send poems to a Wi-Fi Mysql database. Something like this:
Sensor 1 and 2 -----> arduino --------> Wifly --------> Mysql
The sensor code :
#include <OneWire.h>
int sensorPin = A0;    // select the input pin for the potentiometer
int sensorValue = 0;  // variable to store the value coming from the sensor
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin); // on digital pin 2
  // declare the ledPin as an OUTPUT:
void loop(void) {
  // read the value from the sensor:
  sensorValue = analogRead(sensorPin);
  Serial.print("sensor de humedad 1 = " );
  Serial.println(sensorValue);
 float temperature = getTemp();
 Serial.print("sensor de temperatura 1 = " );
 Serial.println(temperature);
 delay(1000); //just here to slow down the output so it is easier to read
 Serial.print("----------------------------" );
 Serial.println(" ");
float getTemp(){
 //returns the temperature from one DS18S20 in DEG Celsius
 byte data[12];
 byte addr[8];
 if ( !ds.search(addr)) {
   //no more sensors on chain, reset search
   ds.reset_search();
   return -1000;
 if ( OneWire::crc8( addr, 7) != addr[7]) {
   Serial.println("CRC is not valid!");
   return -1000;
 if ( addr[0] != 0x10 && addr[0] != 0x28) {
   Serial.print("Device is not recognized");
   return -1000;
 ds.reset();
 ds.select(addr);
 ds.write(0x44,1); // start conversion, with parasite power on at the end
 byte present = ds.reset();
 ds.select(addr);
 ds.write(0xBE); // Read Scratchpad
 for (int i = 0; i < 9; i++) { // we need 9 bytes
  data[i] = ds.read();
 ds.reset_search();
 byte MSB = data[1];
 byte LSB = data[0];
 float tempRead = ((MSB << 8) | LSB); //using two's compliment
 float TemperatureSum = tempRead / 16;
 return TemperatureSum;
I recognize all the words. The order that they are arranged in makes no sense. What kind of column definition are you using for the poem column? The database doesn't live on a router, so the WiFi term is confusing.
The WiFi shield lets you connect to an existing local area network that the router is connected to. Beyond that, you need to write code on the Arduino to talk to some server on which the MySQL database is running. It's unlikely that you are storing poems in a database.
I suggest that you try again.
often used configuration is
sensor --> arduino --> network(wifi) --> webserver --> php --> mysql (check out - http://www.apachefriends.org/en/xampp.html - )
as php can handle the login encryption for mysql and arduino can't.
