I need help with break one char into 3 others chars.
Hello everybody,
I want to break one char into another 3 chars.
i did this code:
Variables:
char teste[40] = "#TEMPO JAN 01 2001 01:01:01";
int cont;
char tmp[5] = "0";
char data[10] = "0";
char hora[7] = "0";
loop:
for(cont = 0; cont < 6; cont++){
    tmp[cont] = teste[cont];
  Serial.println(tmp);
  for(cont = 0; cont < 11; cont++){
    data[cont] = teste[cont+7];
  Serial.println(data);
  for(cont = 0; cont < 8; cont++){
    hora[cont] = teste[cont+19];
  Serial.println(hora);
and get my expected result on serial:
#TEMPO
JAN 01 2001
01:01:01
But if i change the serial prints to the end of all “for’s”, like this:
i have this result:
#TEMPOJAN 01 20001:01:01
JAN 01 20001:01:01
01:01:01
i need the first result after all loops, someone can help me?
Sorry for my bad english.
A string is a NULL terminated array of chars, NOT just an array of chars. Your for loops are not NULL terminating the array, so when you print the array, printing happens until a NULL is found, belonging to some other variable.
    tmp[cont+1] = '\0'; // NULL terminate the array.
Your loop tests are wrong, off by one. Should be cont < 5, cont < 10 and cont < 7 respectively. Or alternatively you array sizes are wrong.
#TEMPO” is 6 chars long, so you need a 7 char array.
“JAN 01 2001” is eleven chars long, so you need a 12 char array.
“01:01:01” is 8 chars long so you need a 9 char array.
Very simple code that might do what you want.
//send string using serial monitor
String readString, data1, data2, data3;
  Serial.println("parse-test-3"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(2);
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if (readString.length() >0) {
    Serial.println(readString); //see what was received
    // expect a string like #TEMPO JAN 01 2001 01:01:01 with three data partts
    data1 = readString.substring(0, 6); //get the first three characters
    data2 = readString.substring(7, 18); //get the next three characters
    data3 = readString.substring(19, 28); //get the next three characters
    Serial.println(data1);  //print to serial monitor to see results
    Serial.println(data2);
    Serial.println(data3);
    readString="";
    data1="";
    data2="";
    data3="";
zoomkat:
    delay(2);
readString="";
    data1="";
    data2="";
    data3="";
Thanks all for help, i fixed it.
