I need help with count up timer code!!
So i have this code and I dont have lcd yet but when I try to print it on serial monitor it keeps printing numbers into infinity in one row. Can somebody help?
#include<print.h>
#include <LiquidCrystal.h>
#include <TimeLib.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_LEDBackpack.h>
#include <Adafruit_GFX.h>
#include <RTClib.h>
#define BACKLIGHT_PIN     13
RTC_DS1307 rtc = RTC_DS1307();
LiquidCrystal_I2C lcd(0x38); //set LCD I2C address
const uint8_t charBitmap[][8] =
   { 0xc, 0x12, 0x12, 0xc, 0, 0, 0, 0 },
   { 0x6, 0x9, 0x9, 0x6, 0, 0, 0, 0 },
   { 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0, 0x0 },
   { 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0, 0x0 },
   { 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0x0 },
   { 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0x0 },
   { 0x0, 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0x0 },
   { 0x0, 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0x0 }
int hours = 0;
int minutes = 0;
int seconds = 0;
int weeks ;
unsigned long days ;
unsigned long previousMillis = 0;        // will store last millis event time
unsigned long sensorpreviousMillis = 0;        // will store last millis event time
unsigned long fiveMinuteInterval = 300000;           // interval at which to use event time (milliseconds)
unsigned long postDaysInterval = 7200000 ; //seconds in a day 86400000
unsigned long theDateWeGotTogether = 1470243600   ;  //in unixtime
  int charBitmapSize = (sizeof(charBitmap ) / sizeof (charBitmap[0]));
  pinMode ( BACKLIGHT_PIN, OUTPUT );
  digitalWrite ( BACKLIGHT_PIN, HIGH );
  rtc.begin();
  lcd.begin(16,2);
  for ( int i = 0; i < charBitmapSize; i++ )
      lcd.createChar ( i, (uint8_t *)charBitmap[i] );
 bool setClockTime = !rtc.isrunning();
 if (setClockTime) {
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
//  DateTime now = rtc.now();
  days = ((now() - theDateWeGotTogether) / 86400); //86400 is the number of seconds in a day
  unsigned long int currentMillis = millis();
  ShowDaysReading();
  time_t t = now();
  if(currentMillis - sensorpreviousMillis > fiveMinuteInterval)
    // save the last time you performed event
    sensorpreviousMillis = currentMillis;
void ShowDaysReading()
  days = ((now() - theDateWeGotTogether) / 86400); //86400 number of seconds in a day
  weeks = ((now() - theDateWeGotTogether) / (86400* 7) ); //86400 number of seconds in a day
  lcd.print(days);
  Serial.print(days);
Sorry, I tried to compile your program, but there are SO many different libraries that I am missing at least one.
Apparently you have not tried any debugging by printing the intermediate values. Try "Serial.write( name of what is potentially causing problem);. Perhaps doing the same for each variable in your program. This is called "debugging" and you need to learn a bit about it.
Paul
No surprise as you are not printing a newline character.
Try
 Serial.println(days);
Hey Paul_KD7HB thanks for tip, I am still new to this. UKHeliBob thanks for advice, i did it but i think thats not resukt i was expecting. Can I ask someone to try and compile this code? All libraries are listed in #included.
Why do you include ALL those libraries? Are they really being used? Have you tried debugging using Serial.print, etc?
Paul
My bad, I can compile it with just these libraries
#include <RTClib.h>
What did you get ? What were you expecting ?
I want to print days from specific days to lcd (which idont have yet) and to serial monitor. I get “32693” number printing every milisecond.
