I need help with i2C code
I want to communicate with a vacuum cleaner battery using i2C.
I think i wrote the right code, but it keeps returning only -1. Can you help me?
#include <Wire.h>
const byte batteryAddress = 0x49;
const byte voltageRegister = 0x09;
  Wire.begin();
  float batteryVoltage = readBatteryVoltage(batteryAddress, voltageRegister);
  Serial.print("Battery Voltage: ");
  Serial.print(batteryVoltage);
  Serial.println(" V");
float readBatteryVoltage(int deviceAddress, byte registerAddress)
  float voltage = 0.0;
  Wire.beginTransmission(deviceAddress);
  Wire.write(registerAddress);
  Wire.endTransmission();
  Wire.requestFrom(deviceAddress, 2);
  byte highByte = Wire.read();
  byte lowByte = Wire.read();
  int voltage = (highByte << 8) | (lowByte >> 8);
  return voltage;
Welcome to the forum.
If you haven't read it yet, read the thread:
"How to get the best out of this forum
Which "arduino" are you using?
Run I2Cscanner.ino and see if it finds the addresses of the module(s).
"Arduino Playground - I2cScanner
Check the return code.
lowByte does not deserve shifting.
Are you sure it's I2C; not SMBus - or even PMBus?
