I need help with inputs from serial
I'm rather new to Arduino and cant understand what I'm doing wrong.
any help is appreciated.
char input;
if (Serial.available() > 0) {
input = Serial.read();
if(input == 1){
for(int x = 0; x < 50; x++) {
Serial.println("1");
else if(input == 2){
Serial.println("2");
else if(input == 3){
Serial.println("3");
else;
thank you
Your problem is scope.
"input" is only visible in setup,().
Your tests for equality should probably use single quotes, e.g. "if (input == '1')" etc
TheMemberFormerlyKnownAsAWOL answered it while I was writing this, but there is a bit of extra information so I'll post it anyway:
When you type a 1 into Serial Monitor, the ASCII value for 1 is received via Serial.read(). The ASCII value of the character 1 is 49:
https://forum.arduino.cc/index.php?topic=659158
but you don't need to know that because you can just do a comparison with the character 1 like this:
if(input == '1'){
OK, first things first.
You need to go and read the forum instructions so that you can go back and modify your original post (not re-post it - using the "More -> Modify" option below the right hand corner of your post - to mark up your code as such using the "</>" icon in the posting window. Just highlight each section of code (or output if you need to post that) from the IDE and click the icon.
In fact, the IDE itself has a "copy for forum" link to put these markings on a highlighted block for you so you then just paste it here in a posting window. But even before doing that, don't forget to use the "Auto-Format" (Ctrl-T) option first to make it easy to read. If you do not post it as "code" it can as you now see, be quite garbled and is always more difficult to read due to the font.
It is inappropriate to attach it as a ".ino" file unless it is clearly too long to include in the post proper. People can usually see the mistakes directly and do not want to have to actually load it in their own IDE. And even that would also assume they are using a PC and have the IDE running on that PC.
Also tidy up your blank space. Do use blank lines, but only single blanks between complete functional blocks.
