I need help with LiquidCrystal_I2C.h
no matter what I do I will always get this message:
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
HelloWorld:1:10: fatal error: LiquidCrystal_I2C.h: No such file or directory
compilation terminated.
exit status 1
option enabled in File -> Preferences.
the code:
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4);
lcd.init();
lcd.init();
lcd.backlight();
lcd.setCursor(1,0);
lcd.print("hello everyone");
lcd.setCursor(1,1);
lcd.print("konichiwaa");
I've tried everything I want in every form and can't find a solution.
What do I do?
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Do you have this library installed on your PC ?
yes
Have you tried to use the LCD examples for the LCD library that is installed?
Why not post, in code tags, your code?
Which folder are the library files installed in ?
C:\Users\evyat\OneDrive\Documents\Arduino\libraries
Which folder is the sketch in ?
Do other libraries that you have installed work ?
At the back of my mind I have feeling that OneDrive can cause problems
Can the IDE see the library if you do sketch/Include Library ?
the other ones don't work...
Mabey it is the OneDrive I will try that
that worked thank you so much❤️
You are welcome
Good luck with your project going forward
Just to help all of us, please check Solution :white_check_mark: under UKHeliBob's post to indicate more easily it is the answer. Remember, this thread helps others too!
@anon44338819
