Me and my dad made a door lock with the arduino. Now we found out that when the Arduino loses power it forgets all the tags we added. Is there a way to save them to the EEprom or to the arduino. So that when it loses power and we turn it on again we don't have to add all the tags again.
#include <SPI.h>
#include <MFRC522.h>
#include <LiquidCrystal.h>
#include <Servo.h>
#include <EEPROM.h>
#define RST_PIN 9
#define SS_PIN 10
byte readCard[4];
char* myTags[100] = {};
int tagsCount = 0;
String tagID = "";
boolean successRead = false;
boolean correctTag = false;
int proximitySensor;
boolean doorOpened = false;
// Create instances
MFRC522 mfrc522(SS_PIN, RST_PIN);
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); //Parameters: (rs, enable, d4, d5, d6, d7)
Servo myServo; // Servo motor
// Initiating
Serial.println("Test prox sensor");
SPI.begin(); // SPI bus
mfrc522.PCD_Init(); // MFRC522
lcd.begin(16, 2); // LCD screen
//myServo.attach(8); // Servo motor
pinMode(8, OUTPUT); //relais
myServo.write(10); // Initial lock position of the servo motor
// Prints the initial message
lcd.print("-No master tag!-");
lcd.setCursor(0, 1);
lcd.print(" SCAN NOW");
// Waits until a master card is scanned
while (!successRead) {
successRead = getID();
if ( successRead == true) {
myTags[tagsCount] = strdup(tagID.c_str()); // Sets the master tag into position 0 in the array
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Master Tag Set!");
tagsCount++;
printNormalModeMessage();
int proximitySensor = analogRead(A0);
Serial.println(proximitySensor);
// If door is closed...
if (proximitySensor > 200) {
if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
return;
if ( ! mfrc522.PICC_ReadCardSerial()) { //Since a PICC placed get Serial and continue
return;
tagID = "";
// The MIFARE PICCs that we use have 4 byte UID
for ( uint8_t i = 0; i < 4; i++) { //
readCard[i] = mfrc522.uid.uidByte[i];
tagID.concat(String(mfrc522.uid.uidByte[i], HEX)); // Adds the 4 bytes in a single String variable
tagID.toUpperCase();
mfrc522.PICC_HaltA(); // Stop reading
correctTag = false;
// Checks whether the scanned tag is the master tag
if (tagID == myTags[0]) {
lcd.clear();
lcd.print("Program mode:");
lcd.print("Add/Remove Tag");
for (int i = 0; i < 100; i++) {
if (tagID == myTags[i]) {
myTags[i] = "";
lcd.clear();
lcd.print(" Tag Removed!");
return;
lcd.clear();
lcd.print(" Tag Added!");
tagsCount++;
return;
// Checks whether the scanned tag is authorized
lcd.clear();
lcd.print(" Access Granted!");
myServo.write(170); // Unlocks the door
digitalWrite(8, HIGH); // turn the LED on (HIGH is the voltage level)
delay(3000); // wait for three seconds
digitalWrite(8, LOW); // turn the LED off by making the voltage LOW
correctTag = true;
if (correctTag == false) {
lcd.clear();
lcd.print(" Access Denied!");
// If door is open...
else {
lcd.clear();
lcd.print(" Door Opened!");
while (!doorOpened) {
if (proximitySensor < 200) {
doorOpened = true;
doorOpened = false;
myServo.write(10); // Locks the door
uint8_t getID() {
// Getting ready for Reading PICCs
return 0;
return 0;
tagID = "";
for ( uint8_t i = 0; i < 4; i++) { // The MIFARE PICCs that we use have 4 byte UID
return 1;
void printNormalModeMessage() {
delay(1500);
lcd.clear();
lcd.print("-Access Control-");
lcd.print(" Scan Your Tag!");
