ENGLISH:
Hello, my name is Lucas and I'm new to the world of programming via Arduino, I'm working on a project for glasses for the visually impaired and in this pair of glasses in its base programming I have to use an HC-SR04 ultrasonic sensor, along with a buzzer on an Arduino nano, the ultrasound sensor, when detecting an object at a distance of less than 1.5 meters (150 centimeters) will send a signal to the buzzer that will make a sound at a frequency of 523hz for 3 seconds. When checking the code, the Arduino IDE application showed that my code has an error:
In function 'void loop()':
22:3: error: 'delayMicrosecods' was not declared in this scope
22:3: note: suggested alternative: 'delayMicroseconds'
36:3: error: expected ';' before 'float'
39:20: error: 'a1' was not declared in this scope
39:20: note: suggested alternative: 'A1'avre[0m 1.8.6 e[90m/home/tcad/.arduino15/packages/arduino/hardware/avr/1.8.6e[0m
exit status 1
I am unable to correct this error, can anyone help me please? Below I leave my current code.
#define trigPin1 3
#define echoPin1 4
#define buzzer 5
pinMode (trigPin1, OUTPUT);
pinMode (echoPin1, INPUT);
pinMode (buzzer, OUTPUT);
Serial.begin(9600); // inicializa biblioteca
// Serial.println ("Passagem na sequencia distancia1")
float duration1, distance1;
digitalWrite(trigPin1, LOW);
delayMicroseconds(2); // delay de 2 microsegundos
digitalWrite (trigPin1, HIGH);
delayMicrosecods(10); //delay de 10 microsegundos
digitalWrite(trigPin1,LOW);
duration1 = pulseIn(echoPin1, HIGH); //pulseIn Lê o tempo entre a chamada e o pino entrar até em sinal HIGH
//esse calculo é baseado em s= v . t, lembrando que o tempo vem dobrado
//porque é o tempo de ida e volta do ultrassom
distance1= (duration1/2) / 29.1;
delay(50)
//fim de leitura distancia1
float a1=distance1;
//float tempo=(float) millis()/60000; //leitura do tempo
// acompanhamento na saida serial para dados de distancia
Serial.println(a1);
if(a1<150.){
tone( buzzer, 523);
delay(300);
noTone(buzzer);
//delay (500);
