I need help with my finals project
I am trying to develop a IOT based pulse and temperature monitoring system. I have been studying arduino for a month now so I can understand the codes a bit. IoT Based Patient Health Monitoring using ESP8266 & Arduino This is the project that I am trying to copy. Since my time studying arduino I know how to create a pulse and temperature monitoring system without the esp8266 esp 01 module, and I have also been able to create the exact circuit diagram shown in the website. But when it comes to connecting the system to the internet with the esp8266 module, that is where my mind goes blank. I have no idea how to upload the BPM and TEMPERATURE to the internet. I tried to copy the websites code but when I try to compile it, about 8 errors would occur. I tried learning how to program with esp8266 module but whatever I find doesn't seem to help. Pls I need some advice.
This is my code
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#include <SoftwareSerial.h>
float pulse = 0;
float temp = 0;
SoftwareSerial ser(9, 10);
String apiKey = " "; // Apply THINGSPEAK api key here
// Variables
int pulsePin = A0; // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 7 ; // pin to blink led at each beat
int fadePin = 13; // pin to do fancy classy fading blink at each beat
int fadeRate = 0; // used to fade LED on with PWM on fadePin
// Volatile Variables, used in the interrupt service routine!
volatile int BPM; // int that holds raw Analog in 0. updated every 2mS
volatile int Signal; // holds the incoming raw data
volatile int IBI = 600; // int that holds the time interval between beats! Must be seeded!
volatile boolean Pulse = false; // "True" when User's live heartbeat is detected. "False" when nota "live beat".
volatile boolean QS = false; // becomes true when Arduoino finds a beat.
// Regards Serial OutPut -- Set This Up to your needs
static boolean serialVisual = true; // Set to 'false' by Default. Re-set to 'true' to see Arduino Serial Monitor ASCII Visual Pulse
volatile int rate[10]; // array to hold last ten IBI values
volatile unsigned long sampleCounter = 0; // used to determine pulse timing
volatile unsigned long lastBeatTime = 0; // used to find IBI
volatile int P = 512; // used to find peak in pulse wave, seeded
volatile int T = 512; // used to find trough in pulse wave, seeded
volatile int thresh = 525; // used to find instant moment of heart beat, seeded
volatile int amp = 100; // used to hold amplitude of pulse waveform, seeded
volatile boolean firstBeat = true; // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = false; // used to seed rate array so we startup with reasonable BPM
lcd.begin(16, 2);
pinMode(blinkPin, OUTPUT); // pin that will blink to your heartbeat!
pinMode(fadePin, OUTPUT); // pin that will fade to your heartbeat!
Serial.begin(115200); // we agree to talk fast!
interruptSetup(); // sets up to read Pulse Sensor signal every 2mS
// IF YOU ARE POWERING The Pulse Sensor AT VOLTAGE LESS THAN THE BOARD VOLTAGE,
// UN-COMMENT THE NEXT LINE AND APPLY THAT VOLTAGE TO THE A-REF PIN
// analogReference(EXTERNAL);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(" Patient Health");
lcd.setCursor(0, 1);
lcd.print(" Monitoring ");
delay(4000);
lcd.clear();
lcd.print("Initializing....");
delay(5000);
lcd.clear();
lcd.print("Getting Data....");
ser.begin(9600);
ser.println("AT");
ser.println("AT+GMR");
ser.println("AT+CWMODE=3");
ser.println("AT+RST");
delay(5000);
ser.println("AT+CIPMUX=1");
String cmd = "AT+CWJAP=" "," ""; //SSID and PASSWORD
ser.println(cmd);
ser.println("AT+CIFSR");
// Where the Magic Happens
serialOutput();
if (QS == true) // A Heartbeat Was Found
// BPM and IBI have been Determined
// Quantified Self "QS" true when arduino finds a heartbeat
fadeRate = 255; // Makes the LED Fade Effect Happen, Set 'fadeRate' Variable to 255 to fade LED with pulse
serialOutputWhenBeatHappens(); // A Beat Happened, Output that to serial.
QS = false; // reset the Quantified Self flag for next time
ledFadeToBeat(); // Makes the LED Fade Effect Happen
delay(20); // take a break
read_temp();
esp_8266();
void ledFadeToBeat()
fadeRate -= 15; // set LED fade value
fadeRate = constrain(fadeRate, 0, 255); // keep LED fade value from going into negative numbers!
analogWrite(fadePin, fadeRate); // fade LED
void interruptSetup()
// Initializes Timer2 to throw an interrupt every 2mS.
TCCR2A = 0x02; // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
TCCR2B = 0x06; // DON'T FORCE COMPARE, 256 PRESCALER
OCR2A = 0X7C; // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
TIMSK2 = 0x02; // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
sei(); // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
void serialOutput()
{ // Decide How To Output Serial.
if (serialVisual == true)
arduinoSerialMonitorVisual('-', Signal); // goes to function that makes Serial Monitor Visualizer
sendDataToSerial('S', Signal); // goes to sendDataToSerial function
void serialOutputWhenBeatHappens()
if (serialVisual == true) // Code to Make the Serial Monitor Visualizer Work
Serial.print("*** Heart-Beat Happened *** "); //ASCII Art Madness
Serial.print("BPM: ");
Serial.println(BPM);
sendDataToSerial('B', BPM); // send heart rate with a 'B' prefix
sendDataToSerial('Q', IBI); // send time between beats with a 'Q' prefix
void arduinoSerialMonitorVisual(char symbol, int data )
const int sensorMin = 0; // sensor minimum, discovered through experiment
const int sensorMax = 1024; // sensor maximum, discovered through experiment
int sensorReading = data; // map the sensor range to a range of 12 options:
int range = map(sensorReading, sensorMin, sensorMax, 0, 11);
// do something different depending on the
// range value:
switch (range)
case 0:
Serial.println(""); /////ASCII Art Madness
case 1:
Serial.println("---");
case 2:
Serial.println("------");
case 3:
Serial.println("---------");
case 4:
Serial.println("------------");
case 5:
Serial.println("--------------|-");
case 6:
Serial.println("--------------|---");
case 7:
Serial.println("--------------|-------");
case 8:
Serial.println("--------------|----------");
case 9:
Serial.println("--------------|----------------");
case 10:
Serial.println("--------------|-------------------");
case 11:
Serial.println("--------------|-----------------------");
void sendDataToSerial(char symbol, int data )
Serial.print(symbol);
Serial.println(data);
ISR(TIMER2_COMPA_vect) //triggered when Timer2 counts to 124
cli(); // disable interrupts while we do this
Signal = analogRead(pulsePin); // read the Pulse Sensor
sampleCounter += 2; // keep track of the time in mS with this variable
int N = sampleCounter - lastBeatTime; // monitor the time since the last beat to avoid noise
// find the peak and trough of the pulse wave
if (Signal < thresh && N > (IBI / 5) * 3) // avoid dichrotic noise by waiting 3/5 of last IBI
if (Signal < T) // T is the trough
T = Signal; // keep track of lowest point in pulse wave
if (Signal > thresh && Signal > P)
{ // thresh condition helps avoid noise
P = Signal; // P is the peak
} // keep track of highest point in pulse wave
// NOW IT'S TIME TO LOOK FOR THE HEART BEAT
// signal surges up in value every time there is a pulse
if (N > 250)
{ // avoid high frequency noise
if ( (Signal > thresh) && (Pulse == false) && (N > (IBI / 5) * 3) )
Pulse = true; // set the Pulse flag when we think there is a pulse
digitalWrite(blinkPin, HIGH); // turn on pin 13 LED
IBI = sampleCounter - lastBeatTime; // measure time between beats in mS
lastBeatTime = sampleCounter; // keep track of time for next pulse
  if (secondBeat)
  { // if this is the second beat, if secondBeat == TRUE
    secondBeat = false; // clear secondBeat flag
    for (int i = 0; i <= 9; i++) // seed the running total to get a realisitic BPM at startup
      rate[i] = IBI;
  if (firstBeat) // if it's the first time we found a beat, if firstBeat == TRUE
    firstBeat = false; // clear firstBeat flag
    secondBeat = true; // set the second beat flag
    sei(); // enable interrupts again
    return; // IBI value is unreliable so discard it
  // keep a running total of the last 10 IBI values
  word runningTotal = 0; // clear the runningTotal variable
  for (int i = 0; i <= 8; i++)
  { // shift data in the rate array
    rate[i] = rate[i + 1]; // and drop the oldest IBI value
    runningTotal += rate[i]; // add up the 9 oldest IBI values
  rate[9] = IBI; // add the latest IBI to the rate array
  runningTotal += rate[9]; // add the latest IBI to runningTotal
  runningTotal /= 10; // average the last 10 IBI values
  BPM = 60000 / runningTotal; // how many beats can fit into a minute? that's BPM!
  QS = true; // set Quantified Self flag
  // QS FLAG IS NOT CLEARED INSIDE THIS ISR
  pulse = BPM;
if (Signal < thresh && Pulse == true)
{ // when the values are going down, the beat is over
digitalWrite(blinkPin, LOW); // turn off pin 13 LED
Pulse = false; // reset the Pulse flag so we can do it again
amp = P - T; // get amplitude of the pulse wave
thresh = amp / 2 + T; // set thresh at 50% of the amplitude
P = thresh; // reset these for next time
T = thresh;
if (N > 2500)
{ // if 2.5 seconds go by without a beat
thresh = 512; // set thresh default
P = 512; // set P default
T = 512; // set T default
lastBeatTime = sampleCounter; // bring the lastBeatTime up to date
firstBeat = true; // set these to avoid noise
secondBeat = false; // when we get the heartbeat back
sei(); // enable interrupts when youre done!
}// end isr
void esp_8266()
// TCP connection AT+CIPSTART=4,"TCP","184.106.153.149",80
String cmd = "AT+CIPSTART=4,"TCP","";
cmd += "184.106.153.149"; // api.thingspeak.com
cmd += "",80";
ser.println(cmd);
Serial.println(cmd);
if (ser.find("Error"))
Serial.println("AT+CIPSTART error");
return;
String getStr = "GET /update?api_key=";
getStr += apiKey;
getStr += "&field1=";
getStr += String(temp);
getStr += "&field2=";
getStr += String(pulse);
getStr += "\r\n\r\n";
// send data length
cmd = "AT+CIPSEND=4,";
cmd += String(getStr.length());
ser.println(cmd);
ser.print(getStr);
Serial.println(getStr); //thingspeak needs 15 sec delay between updates
delay(3000);
void read_temp()
int temp_val = analogRead(A1);
float mv = (temp_val / 1024.0) * 5000;
float cel = mv / 10;
temp = (cel * 9) / 5 + 32;
Serial.print("Temperature:");
Serial.println(temp);
lcd.clear();
lcd.print("BPM :");
lcd.setCursor(7, 0);
lcd.print(BPM);
lcd.print("Temp.:");
lcd.setCursor(7, 1);
lcd.print(temp);
lcd.setCursor(13, 1);
lcd.print("F");
And the errors are
Blink:193:5: error: expected constructor, destructor, or type conversion before '(' token
193 | ISR(TIMER2_COMPA_vect) //triggered when Timer2 counts to 124
C:\Users\narut\AppData\Local\Temp\arduino_modified_sketch_740354\Blink.ino: In function 'void interruptSetup()':
Blink:108:1: error: 'TCCR2A' was not declared in this scope
108 | TCCR2A = 0x02; // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
Blink:109:1: error: 'TCCR2B' was not declared in this scope
109 | TCCR2B = 0x06; // DON'T FORCE COMPARE, 256 PRESCALER
Blink:110:1: error: 'OCR2A' was not declared in this scope
110 | OCR2A = 0X7C; // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
Blink:111:1: error: 'TIMSK2' was not declared in this scope
111 | TIMSK2 = 0x02; // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
C:\Users\narut\AppData\Local\Temp\arduino_modified_sketch_740354\Blink.ino: At global scope:
Blink:193:4: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\narut\AppData\Local\Temp\arduino_modified_sketch_740354\Blink.ino: In function 'void read_temp()':
Blink:306:27: error: 'A1' was not declared in this scope; did you mean 'A0'?
306 | int temp_val = analogRead(A1);
| A0
exit status 1
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
You appear to be trying to use code for an AVR on an 8266.
I guess I am. When it comes to esp8266 I really have no idea.
