I need help with my Magic Morse project
I'm currently attempting to recreate this project. I'm using the code it provides, but I want to change some things. I'm brand new to Arduino and to coding in general. Could someone take a look at the code and help me make some changes?
Here is the schematic I just made. I wired the parts according to the code. Everything works how it should.
Here's what I've got it to do so far:
  • prints "SUPER MORSE CODER 3000"
  • small delay
  • screen clears
  • cursor moves to the upper left position
This is perfect. The only thing I have left is to figure out how to make the LED and buzzer turn on while the Morse key is being held down. So I want to use something similar to
MorseKeyState = !digitalRead(morseInPin);
if (MorseKeyState = true) {
  digitalWrite(LED, HIGH);    //Turns LED on
  digitalWrite(BUZ, HIGH);    //Turns buzzer on
  digitalWrite(LED, LOW);     //Turns LED off
  digitalWrite(LED, LOW);     //Turns buzzer off
for:
I'm getting the error
"'MorseKeyState' was not declared in this scope"
What this the correct way to declare MorseKeyState?
Is this the correct way to state the condition?
I also would like to know if it is possible to use a switch to turn the Arduino on and off.
I'de be grateful for any help/tips you have to offer
in the following statement the = operator is assignment
which assigns MorseKeyState the value true hence the the first part of of the if() is always executed try using the comparision operator
if (MorseKeyState == true) {
or even
if (MorseKeyState) {
if MorseKeyState is true etc
Assuming you want the variable to be an integer, at the start of the program before any functions put
int MorseKeyState;
That declares it as a global variable that can be accessed anywhere in your sketch.
