I need help with my programming for "if" structure
Cant get this work when it comes to “if(digitalRead(4) == LOW)”.
The flow of the program is when digital read 3 is high, there will be an increment in the touchcounter making if(touchcounter == 1 ) to be true. Next is reading the state of (digitalRead(4) == LOW), if its true the counter will increment to the counter . if(counter == 1), the program will run. the problem im facing right now is having the program stuck at “if(digitalRead(4) ==LOW)”.
here is the full programming :
int touch = 3;
int button = 4;
int led = 12;
int touchcounter;
int counter;
pinMode(4, INPUT_PULLUP);
pinMode(3, INPUT);
pinMode(12, OUTPUT);
pinMode(A0, INPUT);
pinMode(A1, INPUT);
counter = 0;
touchcounter = 0;
if(digitalRead(3) == HIGH)
touchcounter = touchcounter + 1;
Serial.print("touchcounter: ");
Serial.print(touchcounter);
if(touchcounter == 1)
counter = counter + 1;
Serial.println("push counter: ");
Serial.print(counter);
if(counter == 1)
int val;
int dat;
val=analogRead(0);//Connect LM35 on Analog 0
dat=(500 * val) /1024;;
Serial.print(“Temp:”); //Display the temperature on Serial monitor
Serial.print(dat);
Serial.println(“C”);
if(dat>25)
digitalWrite(12, HIGH);
digitalWrite(12, LOW);
if(counter == 2)
int val1;
val1=analogRead(1);
Serial.println(val1,DEC);
delay(100);
if(val1>500)
counter = counter - 2;
if(touchcounter == 2)
counter = 0;
touchcounter = touchcounter - 2;
Serial.print(“System is shutdown”);
MYASSIGNMENT.ino (1.71 KB)
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Check your analogRead(0) it should be analogRead(A0)
likewise your other analogRead
Thanks.. Tom.. :slight_smile:
You are aware that to increment the push counter, pin 3 must be high and pin 4 must be low at basically the same time (ok, you have given yourself 500 ms to take your finger of the touch and onto the button).
