I need help with Processing!
Hey guys, i'm fairly new to this Arduino and Processing thing. I can pretty much turn an LED on, off, blink, fade....and that's about it. I really would like to learn a TON more about it! And that's where i need your help. Can anyone give me some advice on using processing with the Arduino? One thing i had in mind was to set up 2 circles in Processing, so that when ever i moved my mouse over them, the corresponding LEDs on my Arduino would light up. Any tips? thanks! :wink:
http://www.arduino.cc/playground/Interfacing/Processing
http://webzone.k3.mah.se/projects/arduino-workshop/projects/arduino_meets_processing/instructions/index.html
You might want to check out DANIEL SHIFFMANS book on "Learning Processing".
Fry's "O'reilly book" on "Visualizing Data" is pretty cool too.
look at my project:- http://www.thebox.myzen.co.uk/Hardware/Mini_Monome.html. While it is for a monome there are some test sketches in processing that interact with the monome in the same way you mentioned.
I can recommend the "Learning Processing" book too. Nice and clearly written.
