right now in my code i can only put in 1 digit lines and I want to know how to type in lines like “turn led on” in to the serial. Can someone help me with that?
int ledPin = 13;
pinMode(ledPin, OUTPUT);
while (Serial.available() == 0);
int val = Serial.read();
if (val == '1')
Serial.println("LED is ON");
digitalWrite(ledPin, HIGH);
else if (val == '0')
Serial.println("LED is OFF");
digitalWrite(ledPin, LOW);
Serial.println("Invalid");
Serial.readString();
mattmac553:
if (val == ‘1’)
Serial.println(“LED is ON”);
else if (val == ‘0’)
Serial.println(“LED is OFF”);
Serial.println(“Invalid”);
Here’s a line input function that I wrote a long time ago and use it for everything. The code should be self explanatory.
char buffer [32];
char name [16];
int age;
void setup (void)
Serial.begin (115200);
sprintf (buffer, "\r\nPlease enter your name: ");
Serial.print (buffer);
readline (buffer, 16); // read user name (16 chars limit)
strncpy (name, buffer, 16); // copy entered name into "name"
sprintf (buffer, "\r\nPlease enter your age: ");
readline (buffer, 16); // get user input
age = atoi (buffer); // convert typed ascii to int
sprintf (buffer, "\r\nHello %s, you are %d years old!\r\n", name, age);
void loop (void)
// read a line from user into buffer, return char count
int readline (char *buf, int limit)
int ptr = 0;
char c;
*buf = 0; // clear first char in buffer
while (1) {
if (Serial.available()) {
c = Serial.read();
if (c == 0x0D) { // cr == end of line
return ptr; // return char count
if (c == 0x08) { // backspace
if (ptr > 0) {
ptr--;
buf[ptr] = 0;
Serial.print ( (char) 0x08); // erase bs'd char
Serial.print ( (char) 0x20);
Serial.print ("\a");
if (ptr < (limit - 1)) {
Serial.print ( (char) c);
buf[ptr] = c;
ptr++;
The “readline” function takes a pointer to a buffer, an int which says how many chars to accept (to avoid overrunning the buffer) and it returns a character count of how many characters were typed.
For your use, you would use atoi() to get the integer value of an ascii number in the buffer. You can use atof() to get a floating point number instead (for example, to get the proper value of “1234.567”).
I want to know how to type in lines like "turn led on"
Simple serial test code.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
Serial.println("serial on/off test 0021"); // so I can keep track
while (Serial.available()) {
delay(3);
char c = Serial.read();
readString += c;
if (readString.length() >0) {
Serial.println(readString);
if (readString == "on")
if (readString == "off")
readString="";
