Hello,
I have written an program for aan automatic petfeeder that uses an real time clock.
Its almost correct but there are some problems.
After 5 seconds it shows the time and date of the real time clock but not very clear.
It shows "petfeeder" perfect in the first 5 seconds so i don't know why it won't show it clear after the setup.
Also after the 5 seconds the Servo turns constantly instead of when the feeding time is the same as the real time like i have written in the program.
I don't have any failure messages yet.
I am using an RTC DS1302, servo for an plate that turn 45 degrees so there is an hole where the food can fall in, potentiometer for changing the feeding time, a button so i can go to the feeding time and changing the hours and minutes separately and an lcd with I2C where i display the actual time and date but when i change the feeding time it says "feeding time" and shows the time you are setting.
anyone who can help me find the problem.
//REAL TIME CLOCK MODULE
// CONNECTIONS:
// DS1302 CLK/SCLK --> 5
// DS1302 DAT/IO --> 4
// DS1302 RST/CE --> 2
// DS1302 VCC --> 3.3v - 5v
// DS1302 GND --> GND
#include <ThreeWire.h>
#include <RtcDS1302.h>
ThreeWire myWire(4,5,2); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
int uur;
int minuten;
int seconden;
//SERVO
#include <Servo.h>
Servo myservo;
//LCD SCHERM
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
//POTENTIOMETER
const int pinPotentiometer = A0;
int resultaatUUR = 0;
int resultaatMINUUT = 0;
//KNOP
const byte button = 7;
byte buttonState = 0;
byte lastButtonState = HIGH;
byte buttonCounter = 0;
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 50; // the debounce time; increase if the output flickers
// Generally, you should use "unsigned long" for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won't change:
const long interval = 1000; // interval at which to blink (milliseconds)
void setup ()
Serial.begin(57600);
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
if (!Rtc.IsDateTimeValid())
// Common Causes:
// 1) first time you ran and the device wasn't running yet
// 2) the battery on the device is low or even missing
Serial.println("RTC lost confidence in the DateTime!");
Rtc.SetDateTime(compiled);
if (Rtc.GetIsWriteProtected())
Serial.println("RTC was write protected, enabling writing now");
Rtc.SetIsWriteProtected(false);
if (!Rtc.GetIsRunning())
Serial.println("RTC was not actively running, starting now");
Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
Serial.println("RTC is older than compile time! (Updating DateTime)");
else if (now > compiled)
Serial.println("RTC is newer than compile time. (this is expected)");
else if (now == compiled)
Serial.println("RTC is the same as compile time! (not expected but all is fine)");
//LCD SCHERM
lcd.init();
lcd.backlight();
lcd.setCursor(1,0);
lcd.print("Petfeeder");
delay(5000);
//SERVO
myservo.attach(13);
myservo.write(55);
//POTENTIOMETER
pinMode(pinPotentiometer, INPUT);
//KNOP
pinMode(button, INPUT_PULLUP);
} //END of s e t u p ( )
bool modeInstellen = false;
void loop ()
printDateTime(now);
int reading = digitalRead(button);
// check to see if you just pressed the button
// (i.e. the input went from LOW to HIGH), and you've waited long enough
// since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonState) {
// reset the debouncing timer
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer than the debounce
// delay, so take it as the actual current state:
// if the button state has changed:
if (reading != buttonState) {
buttonState = reading;
// only toggle the LED if the new button state is HIGH
if (buttonState == LOW) {
modeInstellen = !modeInstellen;
/*Serial.print("MI:");
Serial.println(modeInstellen);*/
//KNOP + POTENTIOMETER
if(modeInstellen == true)
checkButton();
if (buttonCounter == 1)
lcd.clear();
lcd.setCursor(1,0);
lcd.print("ingesteld feed uur");
lcd.setCursor(1,1);
lcd.print("00:00");
if (buttonCounter == 2)
int valueUUR = analogRead(pinPotentiometer); //0 1023
Serial.println(valueUUR);
resultaatUUR = valueUUR / 42.625 ;
lcd.setCursor(1,0);
lcd.setCursor(1,1);
if(resultaatUUR < 10)
lcd.print("0");
lcd.print(resultaatUUR);
Serial.println(resultaatUUR);
lcd.print(":00");
if (buttonCounter == 3)
int valueMINUUT = analogRead(pinPotentiometer); //0 1023
Serial.println(valueMINUUT);
resultaatMINUUT = valueMINUUT / 17.05 ;
lcd.setCursor(3,1);
lcd.print(":");
lcd.setCursor(4,1);
if(resultaatMINUUT < 10)
lcd.print("0");
lcd.print(resultaatMINUUT);
Serial.println(resultaatMINUUT);
if (buttonCounter == 4)
buttonCounter = 0;
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
if (!now.IsValid())
// Common Causes:
// 1) the battery on the device is low or even missing and the power line was disconnected
//SERVO
Serial.println(uur);
Serial.println(minuten);
Serial.println(seconden);
if(uur == resultaatUUR && minuten == resultaatMINUUT && seconden == 00)
myservo.write(100);
myservo.write(55);
lastButtonState = reading;
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u/%02u/%04u "),
dt.Month(),
dt.Day(),
dt.Year() );
Serial.print(datestring);
char datestring2[20];
snprintf_P(datestring2,
countof(datestring2),
PSTR("%02u:%02u:%02u"),
dt.Hour(),
dt.Minute(),
dt.Second() );
uur = dt.Hour();
minuten = dt.Minute();
seconden = dt.Second();
Serial.print(datestring2);
//LCD SCHERM
lcd.clear();
lcd.setCursor(1,0);
lcd.print(datestring);
lcd.setCursor(1,1);
lcd.print(datestring2);
} //END of l o o p ( )
void checkButton()
buttonState = digitalRead(button);
if (lastButtonState != buttonState)
lastButtonState = buttonState;
//has the button been released (HIGH is not pushed)
if (buttonState == HIGH)
buttonCounter++;
} //END of c h e c k B u t t o n ( )
