I an unable to send packets to my mcp buffer as my code returns "Failed to send chunck". Can someone help me to fix this? I have the code below
Main ino file:
#include "mastercommodule_parameters.h"
#include <mcp_can.h>
#include <SPI.h>
// Initialize CAN bus at 500 kbps
if (CAN.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK) {
Serial.println("CAN Bus Initialized Successfully!");
Serial.println("Error Initializing CAN Bus.");
while (1);
CAN.setMode(MCP_NORMAL); // Set MCP2515 to Normal mode
pulses = 4;
desiredFlowMass = 0.03;
buildMessage();
receiveMessage();
header file:
#ifndef MASTERCOMMODULE_PARAMETERS_H
#define MASTERCOMMODULE_PARAMETERS_H
#include <SPI.h>
//MCP CAN Communication Parameters
const uint32_t MY_ADDRESS = 0x00000001; // Address of this board
const uint32_t BROADCAST_ADDRESS = 0xFFFFFFFF; // All-cast address
const uint32_t SLAVE1_ADDRESS = 0x00000002; // All-cast address
#define csPin 5 //CS pin ID
#define intPin 4 //interrupt pin D
#define MAX_CAN_FRAME_SIZE 7
extern int pulses;
extern float desiredFlowMass;
extern int pulsesR;
extern float desiredFlowMassR;
extern bool CAN_UP;
extern int packetSize;
extern MCP_CAN CAN;
extern bool MSG_ACK;
extern int failMessageCount;
//Seedmeter functions
void processMessage(char* message);
void acknowledgeData();
void receiveMessage();
void sendMessage(char* message);
void buildMessage();
#endif
cpp file:
#include <SPI.h>
extern int pulses = 0;
extern float desiredFlowMass = 0;
extern int pulsesR = 0;
extern float desiredFlowMassR = 0;
extern bool CAN_UP = false;
extern int packetSize = 0;
extern MCP_CAN CAN(csPin);
extern bool MSG_ACK = false;
extern int failMessageCount = 0;
void buildMessage(){
char message[64];
snprintf(message, sizeof(message), "A1:%d;B1:%.2f;", pulses, desiredFlowMass);
sendMessage(message);
void sendMessage(char* message){
int messageLength = strlen(message);
int numChunks = (messageLength / MAX_CAN_FRAME_SIZE) + (messageLength % MAX_CAN_FRAME_SIZE != 0); // Number of chunks required
int chunkIndex = 0;
while (chunkIndex < numChunks) {
uint8_t chunkStart = chunkIndex * MAX_CAN_FRAME_SIZE;
uint8_t chunkEnd = min(chunkStart + MAX_CAN_FRAME_SIZE, messageLength);
// Prepare a chunk of the message
//char chunk[MAX_CAN_FRAME_SIZE + 1]; // +1 for null terminator
strncpy(chunk, message + chunkStart, chunkEnd - chunkStart);
chunk[chunkEnd - chunkStart] = '\0'; // Ensure null termination
uint8_t gesa = CAN.sendMsgBuf(SLAVE1_ADDRESS,0, 8, (uint8_t*)chunk);
Serial.println(gesa );
// Send the chunk as a CAN message
if (CAN.sendMsgBuf(SLAVE1_ADDRESS,0, 8, (uint8_t*)chunk) == CAN_OK) {
Serial.print("Sent Chunk: ");
Serial.println(chunk);
Serial.println("Failed to send chunk");
chunkIndex++;
delay(500); // Small delay to prevent flooding the bus
void processMessage(char* message) {
// Parse the key-value pairs in the message
char buffer[64];
strncpy(buffer, message, sizeof(buffer)-1); // Copy message to buffer
buffer[sizeof(buffer) - 1] = '\0'; // Ensure null-termination
char* pair = strtok(buffer, ";"); // Split by semicolon
while (pair != NULL) {
char* key = strtok(pair, ":"); // Split key and value
char* value = strtok(NULL, ":");
if (key && value) {
if (strcmp(key, "A1") == 0) {
pulsesR = atoi(value); // Convert string to integer
} else if (strcmp(key, "B1") == 0) {
desiredFlowMassR = atof(value); // Convert string to float
pair = strtok(NULL, ";"); // Move to the next pair
// Debug print the updated variables
Serial.print("Updated Pulses: ");
Serial.println(pulses);
Serial.print("Updated Desired Flow Mass: ");
Serial.println(desiredFlowMass);
// Function to send acknowledgment
void acknowledgeData() {
if (!(pulses == pulsesR)){
failMessageCount = failMessageCount + 1;
if (!(desiredFlowMass == desiredFlowMassR)){
if (failMessageCount == 0){
MSG_ACK = true;
Serial.println("Acknowledgment transmission complete");
MSG_ACK = false;
Serial.println("Acknowledgment transmission failed");
void receiveMessage() {
uint32_t canId; // Variable to store the CAN ID
uint8_t senderAddress; // Read sender address
uint8_t len = 0; // Variable to store the length of the message
uint8_t buf[8]; // Buffer for the message data (up to 8 bytes)
if (CAN.checkReceive() == CAN_MSGAVAIL) {
if (CAN.readMsgBuf(&canId, &len, buf) == CAN_OK) {
senderAddress = (uint8_t)(canId & 0xFF); // Keep only the least significant byte
if (senderAddress == MY_ADDRESS || senderAddress == BROADCAST_ADDRESS) {
CAN_UP = true;
char message[64] = {'\0'};
static int messageIndex = 0; // Keeps track of reassembly
for (int i = 0; i < len; i++) {
message[i] = (char)buf[i]; // Convert data to char
message[len] = '\0'; // Null-terminate the string
if (CAN_UP) {
processMessage(message);
acknowledgeData();
