I need help with this code for arduino UNO R3
Hello there, I need help with this code it is assumed that each analogic in control each servo but when I connected the servos only one analogic in did it had to do
Please Help :slight_smile:
Brazo_Robotico_2.0.ino (906 Bytes)
How are the pots wired? Put Serial.begin(9600) in setup() and a serial print after you read each analog input to see what values that analog read is returning. It makes your code more readable if you use A0, A1, A2, ... for your analog input pins.
