I need help with two similar Functions. Testing an Int for text result
I have two functions that are very similar and both have the same problems.
I start by getting a number from the serial buffer then, I send that number to a function. I want the function to produce a result such as the text "TRUE" or "False" for one function, and "In" or "Out" for the other function. I will then be saving the result to variable to later be saved to a SD card.
My SD card results will need to look like this when done.
Log Time    RPM TPS IAP HO2 HO2 Wideband    IGN STP GEAR    CLUTCH  NT
00:00.0         1130    56  44  47  65535           38  26  0   Out TRUE
00:00.2         1180    56  50  47  65535           38  26  0   Out TRUE
Below are both the functions that I am having trouble with. I have trouble initializing them properly and my array size does not work with 2 different text results that have different amount of letters. I hope I have provided enough information, I am struggling to use the proper terms for asking the question. I added comments in the code to help follow my line of thinking.
Could some one help me please?
/////////////////////////////////Parts for function #1/////////////////////////
//Get the variable Clutch from the buffer (buf)
Clutch = buf[CLUTCH] & 0x10;  //clutch must = IN OR OUT, if clutch = 0 it is "out", if clutch = 1 it is "in"
//Send vairable Clutch to function CLUTCHCHECK() and make a "TRUE" or "False" result
char clutchStr[4] = CLUTCHCHECK(Clutch);
///////////////Function#1/////////////////////////////////////////////
//Receive Clutch becomes ClutchState, then test for 0 or 1
char CLUTCHCHECK(int ClutchState)
  char C[4];
  if (ClutchState == 0)
    C = "Out";
  else  // ClutchState should be 1 if it is not 0
    C = "In";
  return C; //return "In" or "Out"
////////////////////////////////////Part for function #2///////////////////////////////////////
//Get the variable Nt from the buffer (buf)
Nt = buf[NEUTRAL] & 0x02;  //neutral    MUST = TRUE OR FALSE (2 = false) (0 = true)
//Send vairable Nt to function NEUTRALCHECK() and make a "TRUE" or "False" result
char neutralStr[6] = NEUTRALCHECK(Nt);
/////////////////////FUNCTION #2/////////////////////////////
//Receive Nt becomes NeutralState, then test for 0 or 2
char NEUTRALCHECK(int NeutralState)
  char N[6];
  if (NeutralState == 0)
    N = "TRUE";
  else  // if not 0, NeutralState should be 2
    N = "FALSE";
  return N;  // return "TRUE" or "FALSE"
The problem is:
 char C[4];
    C = "Out";
does NOT copy the string constant to the character buffer.
You could use character pointers:
char *clutchStr = CLUTCHCHECK(Clutch);
char *CLUTCHCHECK(int ClutchState)
  char *C;
    C = "Out";
    C = "In";
or you could copy the strings around which will use more memory and more time:
char clutchStr[4];
strcpy(clutchStr, CLUTCHCHECK(Clutch));
  char C[4];
    strcpy(C,"Out");
    strcpy(C, "In");
Or you could use the ternary operator and eliminate the functions:
char *clutchStr = Clutch ? "In" : "Out";
#define CLUTCHCHECK(N)  ((0 == (N)) ? "Out" : "In")
#define NEUTRALCHECK(N) ((0 == (N)) ? "TRUE" : "FALSE")
Thank you both for the excellent answers! I will use the ternary operator and eliminate the functions, I like how that really cleans up the code!
I wrote a small sketch to test the Ternary operator method but, I am doing somethings wrong. I am posting the sketch and my errors.
I must not be understanding the proper use of a Ternary operator.
#define CLUTCHCHECK(Clutch)	((0 == (Clutch)) ? "Out" : "In")
#define NEUTRALCHECK(Nt)	((0 == (Nt)) ? "TRUE" : "FALSE")
int Clutch = 0;
int Nt = 0;
 //Clutch = buf[CLUTCH] & 0x10;       //clutch     must = IN OR OUT   if clutch = 0 it is out if clutch = 1 it is in
  Serial.println(Clutch).
  Serial.println(CLUTCHCHECK);
  if (Clutch == 0)
    Clutch = 1;
    Clutch = 0;
 // Nt = buf[NEUTRAL] & 0x02;          //neutral    MUST = TRUE OR FALSE (2 = false) (0 = true)
  NEUTRALCHECK(Nt);
  Serial.println(Nt);
  Serial.println(NEUTRALCHECK);
  if (Nt == 0)
    Nt = 2;
    Nt = 0;
errors
sketch_dec30c.ino: In function 'void loop()':
sketch_dec30c:15: error: request for member 'Serial' in 'Serial.HardwareSerial::<anonymous>.Stream::<anonymous>.Print::println(Clutch, 10)', which is of non-class type 'size_t'
sketch_dec30c:15: error: 'CLUTCHCHECK' was not declared in this scope
sketch_dec30c:31: error: 'NEUTRALCHECK' was not declared in this scope
By the way my sketch just alters the variables back and forth to and prints the results. I hope to see the variable tested and then the result printed on the screen.
cyclegadget:
CLUTCHCHECK(Clutch); <<< CLUTCHCHECK only produces a value “Out” or “In”, which is then discarded
Serial.println(Clutch). <<< The line should end with ; , not . Also, Clutch is still 0 or 1, not “Out” or “In”
Serial.println(CLUTCHCHECK); <<< CLUTCHCHECK needs a parameter
I think what you want is (replace all three lines above with this):
Serial.println( CLUTCHCHECK(Clutch) ); // CLUTCHCHECK produces the value “Out” or “In”, and println prints the resulting value
There is another issue with how you believe CLUTCHCHECK works, but start with trying to fix this first.
Cheers,
John
int Clutch  = 0;
int Nt      = 0;
// Clutch = buf[CLUTCH] & 0x10;       //clutch     must = IN OR OUT   if clutch = 0 it is out if clutch = 1 it is in
  const char*   szClutch = CLUTCHCHECK(Clutch);
  Serial.println(Clutch);
  Serial.println(szClutch);
  Clutch = ((Clutch == 0) ? 1 : 0);
  const char*   szNeutral = NEUTRALCHECK(Nt);
  Serial.println(Nt);
  Serial.println(szNeutral);
  Nt = ((Nt == 0) ? 2 : 0);
The macro version expands inline using more memory with each expansion thus the following may be of preference.
inline char* CLUTCHCHECK(int state) {
    static char* szOUT = "Out";
    static char* szIN  = "In";
    return ((0 == (state)) ? szOUT : szIN);
inline char* NEUTRALCHECK(int state) {
    static char* szTRUE   = "TRUE";
    static char* szFALSE  = "FALSE";
    return ((0 == (state)) ? szTRUE : szFALSE);
Then again perhaps you don't really want a C-string pointer returned as the result of either of these functions.
Thank you lloyddean! I adjusted your sketch for testing. It shows the integer being tested and the result. I think it will work nicely!
My next step is to add it to my logging sketch and see how it looks on the SD card.
I am grateful for your efforts building he macro which shows how the ternary operator works!
Thanks, Mark
int Clutch  = 0;
int Nt      = 0;
  Serial.println("clutch");
  Serial.println(Clutch);    // show the int used
  Serial.write(szClutch);    //print the result
  Serial.println("**************");
  Serial.println("Neutral");
  Serial.println(Nt);           //show the variable used
  Serial.write(szNeutral);      //print the result
  delay(800);
