I need help with Wii pro controller to nintendo switch
im trying to make a wii pro controller to nintendo switch an the two joysticks aren't working as planed heres my code.
#include "SwitchJoystick.h"
#include <NintendoExtensionCtrl.h>
ClassicController classic;
// Create Joystick
SwitchJoystick_ Joystick;
int LXhome;
int LYhome;
int RXhome;
int RYhome;
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = { 6,  7,  8,  9}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {10, 11, 12, 13}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  Joystick.begin(false);
  classic.begin();
  while (!classic.connect()) {
    Serial.println("Classic Controller not detected!");
  LXhome = classic.leftJoyX();
  LYhome = classic.leftJoyY();
  RXhome = classic.rightJoyX();
  RYhome = classic.rightJoyY();
int rightStick(uint8_t input) {
  if (input > 24)
    return 127;
  else if (input > 20)
    return 64;
  else if (input < 8)
    return -127;
  else if (input < 12)
    return -64;
  return 0;
int leftStick(uint8_t input) {
  if (input > 45)
    return 127;
  else if (input > 35)
    return 64;
  else if (input < 15)
    return -127;
  else if (input < 25)
    return -64;
  return 0;
  char customKey = customKeypad.getKey();
  if (customKey == '1'){
  }else if(customKey == '2'){
  }else if(customKey == '3'){
  }else if(customKey == 'A'){
  }else if(customKey == '4'){
  }else if(customKey == '5'){
  }else if(customKey == '6'){
  }else if(customKey == 'B'){
  }else if(customKey == '7'){
  }else if(customKey == '8'){
  }else if(customKey == '9'){
  }else if(customKey == 'C'){
    Joystick.pressButton(13); // capture
    while(true){
      if (customKey != NO_KEY){
        Joystick.releaseButton(13); // capture
  }else if(customKey == '*'){
  }else if(customKey == '0'){
  }else if(customKey == '#'){
  }else if(customKey == 'D'){
  boolean success = classic.update();
  if (!success) {
    Serial.println("Controller disconnected!");
    classic.connect();
    //delay(100);
    //classic.printDebug();
    Joystick.setButton(12, classic.buttonHome());
    Joystick.setButton(2, classic.buttonA());
    Joystick.setButton(1, classic.buttonB());
    Joystick.setButton(3, classic.buttonX());
    Joystick.setButton(0, classic.buttonY());
    Joystick.setButton(4, classic.buttonL());
    Joystick.setButton(5, classic.buttonR());
    Joystick.setButton(6, classic.buttonZL());
    Joystick.setButton(7, classic.buttonZR());
    Joystick.setButton(9, classic.buttonPlus());
    Joystick.setButton(8, classic.buttonMinus());
    if((classic.leftJoyX() <= LXhome + 10 && classic.leftJoyX() >= LXhome - 10) && (classic.leftJoyY() <= LYhome + 10 && classic.leftJoyY() >= LYhome - 10)){
      Joystick.setXAxis(leftStick(LXhome));
      Joystick.setYAxis(leftStick(LYhome));
    }else if(classic.leftJoyX() > LXhome){
      Joystick.setXAxis(leftStick(LXhome + classic.leftJoyX()));
    }else if(classic.leftJoyX() < LXhome){
      Joystick.setYAxis(leftStick(LXhome - classic.leftJoyX()));
    }else if(classic.leftJoyY() > LYhome){
      Joystick.setXAxis(leftStick(LYhome + classic.leftJoyY()));
    }else if(classic.leftJoyY() < LYhome){
      Joystick.setYAxis(leftStick(LYhome - classic.leftJoyY()));
    if((classic.rightJoyX() <= RXhome + 10 || classic.rightJoyX() >= RXhome - 10) && (classic.rightJoyY() <= RYhome + 10 || classic.rightJoyY() >= RYhome - 10)){
      Joystick.setZAxis(leftStick(RXhome));
      Joystick.setRzAxis(leftStick(RYhome));
    }else if(classic.rightJoyX() > RXhome){
      Joystick.setZAxis(leftStick(RXhome + classic.rightJoyX()));
    }else if(classic.rightJoyX() < RXhome){
      Joystick.setRzAxis(leftStick(RXhome - classic.rightJoyX()));
    }else if(classic.rightJoyY() > RYhome){
      Joystick.setZAxis(leftStick(RYhome + classic.rightJoyY()));
    }else if(classic.rightJoyY() < RYhome){
      Joystick.setRzAxis(leftStick(RYhome - classic.rightJoyY()));
    if (classic.dpadUp()) {
      if (classic.dpadLeft()){
        Joystick.setHatSwitch(135);
      }else if (classic.dpadRight()){
        Joystick.setHatSwitch(45);
      }else{
        Joystick.setHatSwitch(0);
    } else if (classic.dpadDown()) {
        Joystick.setHatSwitch(225);
      }else{
        Joystick.setHatSwitch(180);
    } else if (classic.dpadRight()){
        Joystick.setHatSwitch(90);
    }else if (classic.dpadLeft()){
        Joystick.setHatSwitch(270);
    }else{
        Joystick.setHatSwitch(-1);
  Joystick.sendState();
  delay(100);
i need help and I don't know what to do.
Joysticks are not working as supposed, tells nothing. What do they do?
Lots of if else customKey, in the beginning of loop, that do nothing. What is the untention there?
I'm trying to make a switch pro controller with a Wii pro controller and the joysticks aren't working. I move them in any direction and nothing can you help.
and the customKey if else statements are for button combos like in super smash bros ultimate.
"Nothing" is an impossible result in the digital world.....
Start using serial monitor, in the IDE, and debug prints like Serial.print("At position 1") ; Serial.println(joystickvalue);
and so on. Select strategic places as in the beginning of the chain if calculations.
what would be the math for joysticks I cant figure it out.
Start verifying, by debug printing, what You get as raw data. Have You verified You get plausuble values?
I know that the switch joystick max and min are 255 to 0. But the Wii pro controller is different. And for some reason the serial monitor coming from the Leonardo stops abruptly what do I do.
Joysticks usually contains 2 pots. Common Arduino analog reading goes from 0 to 1023. Maybe Your lib is doing some processing.
I'm sorry but I'll leave Your posting. You're not communicating, only posting more and new questions.
Good luck.
