I need help?
Hello,
Im building a project that controlling the speed of a DC motor similar to this: http://itp.nyu.edu/physcomp/Tutorials/HighCurrentLoads
(http://itp.nyu.edu/physcomp/Tutorials/HighCurrentLoads). Also, adding a led bar to get the output of the potentionmeter.
I try to load the code so into the Arduino UNO but i could'nt get to work where as i increase or decrease the motor speed to show the output level on the led bar.
So how can I fix this to make my potentionmeter to respond my led bar, im still a noobie to coding and need help? Can someone put this two code together for me?
-increase or decrease speed;
const int transistorPin = 9;
pinMode(transistorPin, OUTPUT);
int sensorValue = analogRead(A0);
int outputValue = map(sensorValue, 0, 1023, 0, 255);
analogWrite(transistorPin, outputValue);
-Led bar;
const int analogPin = A0; // the pin that the potentiometer is attached to
const int ledCount = 10; // the number of LEDs in the bar graph
int ledPins[] = {
2, 3, 4, 5, 6, 7,8,9,10,11 }; // an array of pin numbers to which LEDs are attached
// loop over the pin array and set them all to output:
for (int thisLed = 0; thisLed < ledCount; thisLed++) {
pinMode(ledPins[thisLed], OUTPUT);
// read the potentiometer:
int sensorReading = analogRead(analogPin);
// map the result to a range from 0 to the number of LEDs:
int ledLevel = map(sensorReading, 0, 1023, 0, ledCount);
// loop over the LED array:
// if the array element's index is less than ledLevel,
// turn the pin for this element on:
if (thisLed < ledLevel) {
digitalWrite(ledPins[thisLed], HIGH);
// turn off all pins higher than the ledLevel:
else {
digitalWrite(ledPins[thisLed], LOW);
Try here
AWOL:
Try here
Thats the project im working on now but i would like to know if you can put together the code because when i try it dont work? Putting the code together for me would be a good help, please? :frowning:
Simplistically, it is this:
(Not compiled yet)
int ledPins[] = {
int sensorValue = 0;
int outputValue = 0;
int sensorReading = 0;
int ledLevel = 0;
    else {
However, you will note that pin 9 is used twice - and you want to use it as a PWM output.
So you need to replace 9 with something else in the ledPins[] array. Perhaps 12 would be acceptable.
Slim112_itt-tech:
Is it correctly reading the potentiometer value?
Is it correctly displaying it in the led bar?
Is it correctly controlling the motor speed?
