I need help
I’m a beginner and I have a homework assignment due in the morning and two of the question are related and I can’t get the first part working. Basically, the program is supposed to find whatever space number you want in a sentence. If the sentence is “This is a sentence” and you say the index is 2, the function findspace is supposed to output 8 because the second space is the 8th character. This is my code:
int pointer;
int findspace;
const char sentance=“This is a sentence”;
const int index=1;
pointer=findspace(sentence,index);
Serial.print(pointer);
int findspace(char phrase,int space); {
int lsent=strlen(phrase);
int spacenum=0;
for (int i=0; i<=lsent; i++) {
if (phrase*==’ ') {*
  • spacenum=spacenum+1;*
  • if (spacenum==space) {*
  • return i;*
  • else {*
  • spacenum=spacenum;*
  • if (i==lsent && spacenum<space) {*
  • return -1;*
You have a function defined inside another function. That won't work. Move the definition of findspace outside of loop.
If you really are in a hurry, then read the How to Use This Forum post right now and learn to post code properly so it won't turn into italics so you don't waste a bunch of time being told to go back and post it right.
Ok, thank you.
Check your variable names for typos. I can see a 'sentance' and 'sentence' that probably need to match.
Why is your code in italics?
