I need help!
Buenas tardes.
Necesito ayuda pues que el error que me sale al compilar el programa es este:
C:\Users\PAULA\Documents\Arduino\sketch_may29d\sketch_may29d.ino: In function ‘void loop()’:
sketch_may29d:34: error: ‘d’ was not declared in this scope
if (d==0){
sketch_may29d:36: error: expected ‘;’ before ‘d’
d++;
sketch_may29d:39: error: ‘du’ was not declared in this scope
if (du==0){
sketch_may29d:40: error: ‘keypad’ was not declared in this scope
char key = keypad.getKey();
sketch_may29d:42: error: ‘decena’ was not declared in this scope
decena=key;
sketch_may29d:48: error: expected primary-expression before ‘}’ token
C:\Users\PAULA\Documents\Arduino\sketch_may29d\sketch_may29d.ino:48:5: warning: return-statement with a value, in function returning ‘void’ [-fpermissive]
sketch_may29d:48: error: expected ‘;’ before ‘}’ token
sketch_may29d:49: error: ‘du’ was not declared in this scope
if ((du==1)&&(u==0)){
sketch_may29d:49: error: ‘u’ was not declared in this scope
sketch_may29d:51: error: expected ‘;’ before ‘u’
u++;
sketch_may29d:53: error: expected primary-expression before ‘}’ token
C:\Users\PAULA\Documents\Arduino\sketch_may29d\sketch_may29d.ino:53:3: warning: return-statement with a value, in function returning ‘void’ [-fpermissive]
sketch_may29d:53: error: expected ‘;’ before ‘}’ token
sketch_may29d:54: error: ‘ud’ was not declared in this scope
if (ud==0){
sketch_may29d:55: error: ‘keypad’ was not declared in this scope
sketch_may29d:57: error: ‘unidad’ was not declared in this scope
unidad=key;
sketch_may29d:63: error: expected primary-expression before ‘}’ token
C:\Users\PAULA\Documents\Arduino\sketch_may29d\sketch_may29d.ino:63:5: warning: return-statement with a value, in function returning ‘void’ [-fpermissive]
sketch_may29d:63: error: expected ‘;’ before ‘}’ token
sketch_may29d:64: error: ‘maxi’ was not declared in this scope
if (maxi=0){
sketch_may29d:65: error: ‘MaxT’ was not declared in this scope
MaxT=(decena*10)+unidad;
sketch_may29d:65: error: ‘decena’ was not declared in this scope
sketch_may29d:65: error: ‘unidad’ was not declared in this scope
sketch_may29d:78: error: ‘u’ was not declared in this scope
if (u<MaxT){
sketch_may29d:78: error: ‘MaxT’ was not declared in this scope
if (u<MaxT){
sketch_may29d:88: error: expected ‘}’ at end of input
exit status 1
Y aquí esta el programa
#include <Key.h>
#include <Keypad.h>
#include <DHT.h>
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
const byte rows = 4;
const byte colums = 4;
char keys[rows][colums] = {
{ ‘1’,‘2’,‘3’, ‘A’ },
{ ‘4’,‘5’,‘6’, ‘B’ },
{ ‘7’,‘8’,‘9’, ‘C’ },
{ ‘#’,‘0’,’*’, ‘D’ }
const byte rowPins[rows] = { 11, 10, 9, 8 };
const byte colPins[colums] = { 7, 6, 5, 4 };
int unidad=0;
int decena=0;
int u=0;
int d=0;
int du=0;
int ud=0;
int maxi=0;
int MaxT=0;
dht.begin();
if (d==0){
Serial.println(“Ingrese una decena”)
d++;
return;
if (du==0){
if (key){
decena=key;
decena=decena-48;
Serial.println (decena);
du++;
return
Serial.println(“Ingrese una unidad”)
u++;
return
if (ud==0){
if (key){
unidad=key;
unidad=unidad-48;
Serial.println (unidad);
ud++;
return
if (maxi=0){
Serial.println (“La temperatura maxima estupulada es”);
Serial.println (MaxT);
maxi++;
delay(3000);
float h = dht.readHumidity();
float t = dht.readTemperature();
if (isnan(h) || isnan(t)) {
Serial.println(“Error”);
return;
if (u<MaxT){
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(“Humedad: “);
Serial.print(h);
Serial.print(” %\t”);
Serial.print("Temperatura: “);
Serial.print(t);
Serial.print(” *C “);
Serial.print(hic);
Serial.print(” *C ");
Serial.println("Ingrese una decena")
Serial.println("Ingrese una decena");
Leo..
Necesitas leer esto
Lee las Normas del foro.
Luego ve a More (abajo a la derecha), click, luego Modify y estas en modo EDICION.
Primero este es un foro en Español. Aunque todos te entiendan “I need help” no es un título apropiado, ni aúnque dijera “Necesito ayuda”. Coloca un título que explique la naturaleza de tu problema.
Todo lo que pusiste son errores y código. Ambos se postean como si fueran código, asi que sigue las indicaciones que pongo a continuación
**Selecciona cada código/errores y click en </> arriba del emoticon **
