I need help
Hi all
I'm new to the arduino programming.
I tried to attach the 4 servo in this code, but it does not work, please help me.
Best Regards!
/*This program puts the servo values into an array,
 reagrdless of channel number, polarity, ppm frame length, etc...
 You can even change these while scanning!*/
#define PPM_Pin 3  //this must be 2 or 3
#define multiplier (F_CPU/8000000)  //leave this alone
int ppm[16];  //array for storing up to 16 servo signals
byte servo[] = {1,4,5,6,7,8,9,10};  //pin number of servo output
#define servoOut  //comment this if you don't want servo output
//#define DEBUG
  Serial.println("ready");
  #if defined(servoOut)
  for(byte i=0; sizeof(servo)-1; i++) pinMode(servo[i], OUTPUT);
  #endif
  pinMode(PPM_Pin, INPUT);
  attachInterrupt(PPM_Pin - 2, read_ppm, CHANGE);
  TCCR1A = 0;  //reset timer1
  TCCR1B = 0;
  TCCR1B |= (1 << CS11);  //set timer1 to increment every 0,5 us
  //You can delete everithing inside loop() and put your own code here
/*  int count;
  while(ppm[count] != 0){  //print out the servo values
    Serial.print(ppm[count]);
    Serial.print("  ");
    count++;
  Serial.println("");*/
  delay(100);  //you can even use delays!!!
void read_ppm(){  //leave this alone
  static unsigned int pulse;
  static unsigned long counter;
  static byte channel;
  static unsigned long last_micros;
  counter = TCNT1;
  TCNT1 = 0;
  if(counter < 710*multiplier){  //must be a pulse if less than 710us
    pulse = counter;
    if(sizeof(servo) > channel) digitalWrite(servo[channel], HIGH);
    if(sizeof(servo) >= channel && channel != 0) digitalWrite(servo[channel-1], LOW);
    #endif
  else if(counter > 1910*multiplier){  //sync pulses over 1910us
    channel = 0;
    #if defined(DEBUG)
    Serial.print("PPM Frame Len: ");
    Serial.println(micros() - last_micros);
    last_micros = micros();
    #endif
  else{  //servo values between 710us and 2420us will end up here
    ppm[channel] = (counter + pulse)/multiplier;
    #if defined(DEBUG)
    Serial.print(ppm[channel]);
    Serial.print("  ");
    #endif
    channel++;
roro42:
Code that writes directly to the Atmel 328 registers is not normally associated with beginners.
Why not use the regular Servo library?
Those words provide no useful information from which to help you. You need to tell us what the program actually does and what you want it to do that is different.
...R
Hi Robin2
thank you very much for the quick answer.
the code is not written by me
"Why not use the regular Servo library?" - because I do not know how, i tried using servo library, I want this code to work, no matter how, please help me.
roro42:
Rule number one when learning to program: don't use code you don't understand.
That leaves you with two options:
  1. Do some research and try to understand what the code does and how it works.
  2. Look for easier code that you can understand. E.g. using the Servo library.
roro42:
There are countless examples online on how to use the Servo library. Do some more research first.
If you still don't understand it, that's fine. Then you can come back here to ask questions. But keep in mind that questions like "it does not work, please help me", or "I do not know how" are completely meaningless. Tell us what you are struggling with, what you do understand, and what you have tried to fix the problems you're facing.
Pieter
please, show me how for 1 servo, so I can understand it more easily
Man, some people are lazy, I'm out.
I'm not lazy, just stupid, right now I'm trying....
PieterP:
roro42:
The Knob and Sweep examples in the IDE both move a single servo using the Servo library. Try those.
When you've got them working make an attempt at your 4 servo program. If it doesn't work for you post your attempt here and tell us in detail what is is doing and what you want it to do that's different.
Steve
I tried for 4 servo,the code is compiled without error, what did I do wrong?
#include <Servo.h>
//#define DEBUG
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
  #endif
  servo1.attach(1);
  servo1.attach(4);
  servo1.attach(5);
  servo1.attach(6);
  TCCR1B = 0;
  int count;
    Serial.print("  ");
    count++;
 // Serial.println("");
  counter = TCNT1;
  TCNT1 = 0;
    pulse = counter;
    #endif
    channel = 0;
    #if defined(DEBUG)
    #endif
    #if defined(DEBUG)
    Serial.print("  ");
    #endif
    channel++;
roro42:
You are trying to learn to swim in the deep end of the pool.
Get a simple program working with a single servo first.
...R
I have seen many codes with pot and servo, these are simple....works, this is more complicated,must be printed value on the array
I do not understand why nobody wants to help me, to show me example for 1 servo (in this code)
roro42:
Because nobody can read your mind to see what you want to do.
We don't have a clue what's wrong with the standard Servo examples.
On top of that, you seem to have put zero effort into trying to understand the examples yourself, and you haven't done any debugging. Like myself and many others have stated before: just saying "help, it doesn't work" is completely useless.
Imagine calling a mechanic and asking "there's a problem with my car, how can I fix it". How on Earth is he supposed to know where the problem lies?
roro42:
Start with one of the working examples and try extending it in small steps testing after each change. If you get stuck, then post your code and explain why you are stuck.
When you are a beginner and lack experience, that is the most reliable (and quickest) way to achieve your goal.
...R
the examples I have seen they are different how to control a servo at 90 dgr, 180 dgr, or with potentiometer, not with array().....I just want to print out signal on pins 1,4,5,6 to control 4 servo, believe me I tried a week
, it's too complicated for me,I admit to be stupid, If I knew, did not ask here.
If anyone wants to help me, I pay him, via paypal contact cristian275cristian@gmail.com
Thank you
roro42:
OK, then just stop. If you're just going to lay down like that then this is over your head. If you want to pay someone to do it then you will have to lay out the specifications. You'll have to be a LOT more exacting than you have shown the proclivity for so far. I doubt you can even get someone to help you for pay unless you can figure out how to communicate what exactly it is that you are trying to do.
I want to build a ppm encoder(i have the code for ppm encoder and it works perfectly )- decoder(the code posted here is a ppm decoder).
i want to decode the signals from the encoder and print out signal for servo.
as far as I know, to the code posted,the servo must be attached using servo library.
You don't need any servos for a ppm decoder that is just going to print out the commands.
yes, i want to print the commands,the posted code does not work, must be used sevo library for print out the signal.
What does it mean to "print out a signal to a servo"?
