I need help!!!
Hi, I'm starting to use Arduino and I got stuck with a project. I can't see where is the error but it is showing up all the time. Really, I don't understand what is the error.
Here is the error:
In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries\Servo\src/Servo.h:63:0,
from C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a.ino:7:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries\Servo\src/avr/ServoTimers.h:57:1: error: expected ',' or ';' before 'typedef'
typedef enum { _timer1, _Nbr_16timers } timer16_Sequence_t;
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.15.0_x86__mdqgnx93n4wtt\libraries\Servo\src/avr/ServoTimers.h:57:41: error: 'timer16_Sequence_t' does not name a type
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a - copia.ino:6:5: error: redefinition of 'int buttonState'
int buttonState = 0
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a.ino:6:5: note: 'int buttonState' previously defined here
int buttonState = 0
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a - copia.ino: In function 'void setup()':
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a - copia.ino:10:6: error: redefinition of 'void setup()'
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a.ino:10:6: note: 'void setup()' previously defined here
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a - copia.ino: In function 'void loop()':
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a - copia.ino:22:6: error: redefinition of 'void loop()'
C:\Users\Acer\Documents\Arduino\sketch_nov20a\sketch_nov20a.ino:23:6: note: 'void loop()' previously defined here
exit status 1
Error compilando para la tarjeta Arduino/Genuino Uno.
Also, here is my code:
#define trigPin 2
#define echoPin 3
#define ledGreen 9
#define ledRed 8
#define button 12
int buttonState = 0
#include <Servo.h>
Servo servo;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(ledGreen, OUTPUT);
pinMode(ledRed, OUTPUT);
pinMode(button, INPUT);
servo.attach(5);
servo.write(0);
long duration;
buttonState = digitalRead(button);
if (buttonState = HIGH)
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
digitalWrite(ledRed,LOW);
digitalWrite(ledGreen,HIGH);
servo.write(180);
servo.write(0);
digitalWrite(ledRed,HIGH);
digitalWrite(ledGreen,LOW);
delay(2000);
Thank you for any help.
int buttonState = 0 // add a ;
No No No buttonState = HIGH
