I NEED HELP
I'm new to this and I need help with my project. I recently got this UNO R3 Super Starter Kit and I thought I'd make a Remote Controlled car out of this. I decided I'd use the IR sensor and the IR Remote to do this. I'll program it so that when I press the "Up" button on the remote, it would cause my Elegoo UNO R3 board to start the DC Motor to turn the wheel of the car. Here is my code but when I upload it, it says error status 1 error compiling for Arduino Uno:
#include <IRremote.h>
#include <IRremoteInt.h>
//www.elegoo.com
//2016.12.9
#include "IRremote.h"
int receiver = 11; // Signal Pin of IR receiver to Arduino Digital Pin 11
/*-----( Declare objects )-----*/
IRrecv irrecv(receiver);     // create instance of 'irrecv'
decode_results results;      // create instance of 'decode_results'
/*-----( Function )-----*/
void translateIR() // takes action based on IR code received
// describing Remote IR codes
  switch(results.value)
  case 0xFF906F: pinMode (3,OUTPUT);
                 pinMode (4,OUTPUT);
                 pinMode (5,OUTPUT);    break;
  }// End Case
void loop()   /*----( LOOP: RUNS CONSTANTLY )----*/
What am I doing wrong?
Did you correctly install the IRremote library?
OK, I give up.
Where is the setup() function in your code ?
I bet it says a whole lot more than just that.
You have no setup() and you never call translateIR()
What do you mean setup()?
nafaey_:
Normal Arduino sketches must have both setup() and loop() functions. Yours appears to have no setup() function
nafaey_:
Click new in the arduino IDE and you get this
