Hello Guys,i need help with something.
Make the 16x2 LCD connection in accordance with your preliminary work.
• Connect HC-05 converter through Rx and Tx pins.
• Connect your blue led to the blank pin you want with a 220Ω resistor.
• (https://play.google.com/store/apps/details?id=braulio.calle.bluetoothRCcontroller&hl
You can download the Arduino Bluetooth RC Car application at = en & gl = US) to your phone.
install it.
• Make the bluetooth connection between the application and the circuit you created,
When the connection is established, turn on the blue led in your circuit.
• By pressing the buttons on the application, as indicated in Table 1, the pressed buttons can be
According to the 16x2 LCD, print the desired texts.
Forward Button F Forward (top row)
Key Pressed (bottom line)
Back Button B Back (top row)
Left Button L Left (top row)
Right Button R Right (top row)
Light Button
(When closed)
W Front Light Switching (top row)
Light Button
(When open)
w Front Light Off (top row)
I need codes. I would be glad if anyone can write their codes. Thank you very much in advance
