I need many, many, many analog inputs...
I have an idea where I need to read data from many, many, many analog inputs. Sure, there are bigger Arduino boards (MEGA) and there are MUX-solutions. But taking the Uno as example, I can connect 6 Analog inputs, each of them connected to a 16 channel multiplexer, which will give med 96 analog inputs. A simliar calculation would give me 512 channels using the MEGA.
But what if I said I need 5000 inputs, how would I solve that?
Is there a way I can "cluster" multiple Arduino boards and have them to work together, i.e. report the result of all 5000 inputs as one sampling?
Maybe I should not use Arduino for this...?
5000 inputs? What is the application if you do not mind me asking?
In theory you could have a giant mux array and squash all the inputs down to 1 analog input pin. The performance would likely be terrible but if you do not need a fast refresh rate on each input it may work.
I do not know, however, what kind of draw backs there might be in terms of signal quality w/ piping a signal through a large number of muxing stages.
jwallinder:
Probably not. To sequentially read 5000 inputs would be time consuming but to read them all at the same time is not something the arduino is suited to without a lot of external hardware.
My application is like this proximity sensing coffe table http://www.instructables.com/id/Infrared-Proximity-Sensing-Coffee-Table-Module/
But with a much higher resolution. I'm thinking of using photosensors (diode, transistor or resistor?).
To achieve high resolution in aspect of length I need many many many of them...
But someone here might have a better solution?
Use a bunch of SPI interface 8-channel ADCs. Can be read much faster than 110uS conversion of Arduino input.
Can still put a mux/analog switch in front of each channel, switch all muxes together, then go right down the line and read each chip.
8,10,12 bit resolution available
http://www.digikey.com/product-search/en/integrated-circuits-ics/data-acquisition-analog-to-digital-converters-adc/2556291?k=mcp3208
With SPI/8 rate (2 MHz) can read a conversion in about 12uS using 3 SPI transfers.
jwallinder:
Cool. I recently completed pretty much the same projects. It only had 128 sensor nodes though and I was able to mux them down in a 2-stage 16:1 mux ( 8:1 followed by 2:1 ) for each of the 8 analog inputs I used. For 128 nodes I had no problems with the performance on a Due but 5K is way more. What resolution / size is this thing going to be?
here's some info on the completed project
http://forum.arduino.cc/index.php?topic=275263.0
bad_crc:
Interactive LED table with proximity detection - Exhibition / Gallery - Arduino Forum
Really cool project.
For what I can see, the resolution of the inputs is a little less than I have in thought. Looking at your video http://youtu.be/6ytknUFyIfs?t=9m32s I would say I would like a more smooth style of the diodes that is lighten up. Maybe an increase of 50% would be enough. I need to prototype this to find the best resolution for my case. Start small! And also, my project is of a size about 4 times your coffe table.
I would appreciate more info how you have solved it, the 2-stage 16:1 mux for instance. Maybe som code sharing etc? I have read your tumblr-blogg, but I'm missing som details.
Use multiple banks of analog muxes into external ADC:
Parts examples:
10 bit ADC http://www.digikey.com/product-detail/en/MCP3008-I%2FP/MCP3008-I%2FP-ND/319422
12 bit ADC http://www.digikey.com/product-detail/en/MCP3208-CI%2FP/MCP3208-CI%2FP-ND/305928
16:1 mux/switch http://www.digikey.com/product-detail/en/DG406DJZ/DG406DJZ-ND/821393
16 into 16 into 1 ADC would be a lot of chips on one board.
Probably want to go surface mount.
Lot of input wires to bring into 1 place.
Maybe do 20 boards with 32 muxes, 2 ADCs, then can spread out a little more and only have 256 inputs into each card. Connect up SPI bus between cards in smart way.
jwallinder:
The 16:1 mux per analog input pin is done with 3 ICs. I have 2 4051 8:1 muxes taking in 16 inputs and reducing down to 2. The outputs of those feed 2 channels on a 4053 2:1 mux whose output feeds an analog pin on the Arduino. I have 4 select lines fed from digital outputs on the Arduino. The 3 least significant bits for the 4-bit select vector feed the 3 select inputs on the 4051. The 4th bit (MSB) for the selects feeds the 4053 select pin.
As far as code, I have the inputs read via a timer interrupt sequence. Each time the interrupt fires, all 8 analog inputs are read and the data stored out into an array I have for all 128 nodes. Inside the interrupt I also update the mux selects so that the next time the interrupt occurs, I'll be reading the values from the next 8 sensors. This process just repeats over and over when I'm in a mode where I care about the IR sensors. When not in IR sensing mode, I just disable the interrupt and turn off the IR LEDS.
Here's the code for the interrupt.
// interrupt routine to read IR array
void TC4_Handler() {
  TC_GetStatus(TC1, 1);
  // now read analog inputs and store sense data into sense array
  ir_sense_data[64 + ir_group_adder]  = analogRead(A0);
  ir_sense_data[80 + ir_group_adder]  = analogRead(A1);
  ir_sense_data[96 + ir_group_adder]  = analogRead(A2);
  ir_sense_data[112 + ir_group_adder] = analogRead(A3);
  ir_sense_data[0 + ir_group_adder]  = analogRead(A6);
  ir_sense_data[16 + ir_group_adder] = analogRead(A7);
  ir_sense_data[32 + ir_group_adder] = analogRead(A4);
  ir_sense_data[48 + ir_group_adder] = analogRead(A5);
  // update sensor group and mux selects for next time through
  if (ir_group < 15 ) {
    ir_group++;
    ir_group = 0;
  ir_group_adder = (ir_group >> 1) + 8*(ir_group & B00000001);
  // update mux controls for next round ( 4 bit mux control )
  digitalWrite(sense_select0, bitRead(ir_group, 3));    // sense mux MSB
  digitalWrite(sense_select1, bitRead(ir_group, 2));
  digitalWrite(sense_select2, bitRead(ir_group, 1));
  digitalWrite(sense_select3, bitRead(ir_group, 0));    // sense mux LSB
I have 16 "sense groups" of 8 sensors. The ir_sense_data[] array stores the analog read data ( 8-bit resolution ). The indexing into the array is a little weird just based on how I have my muxes and IR nodes connected physically. So I read from 1 sense group each time through and my interrupt runs every 6ms or so IIRC so I get a full refresh of all the sensor values every ~50ms. It seems to give good enough responsiveness for object detection.
