To begin with, this program is should be work by input your fingerprint and then the lock will be open. But you also can registes new fingerprint by type the default password with keypad by input 000, and press D for enter . In the setting there will be a 3 choises, (Enroll, Delete, Change password) Enroll is use for input your new fingerprint. Delete is use for delete the fingerprint that saved. And change password is use to change the default password (000). But i have a problem with the password. The setting will be open when i press D, eventhough i don't input the password (000). Can anyone help me?
#include <Keypad.h>
#include <Adafruit_Fingerprint.h>
#if (defined(__AVR__) || defined(ESP8266)) && !defined(__AVR_ATmega2560__)
SoftwareSerial mySerial(11, 10);
#else
#define mySerial Serial1
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
uint8_t id;
LiquidCrystal_I2C lcd(0x27, 16, 2);
int Trig = 0;
int Trig2 = 0;
int Trig3 = 0;
int Trig4 = 0;
int Value = 0;
String pass = "000D";
const byte ROWS = 4; //Four rows
const byte COLS = 4; //Four columns
char keys[ROWS][COLS] = {
{ '1', '2', '3', 'A' },
{ '4', '5', '6', 'B' },
{ '7', '8', '9', 'C' },
{ 'S', '0', 'H', 'D' }
byte rowPins[ROWS] = { 9, 8, 7, 6 }; //connect to the row pinouts of the keypad
byte colPins[COLS] = { 5, 4, 3, 2 }; //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
String v_passcode = "";
while (!Serial)
; // For Yun/Leo/Micro/Zero/...
delay(100);
Serial.println("\n\nAdafruit Fingerprint sensor enrollment");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1) { delay(1); }
Serial.println(F("Reading sensor parameters"));
finger.getParameters();
Serial.print(F("Status: 0x"));
Serial.println(finger.status_reg, HEX);
Serial.print(F("Sys ID: 0x"));
Serial.println(finger.system_id, HEX);
Serial.print(F("Capacity: "));
Serial.println(finger.capacity);
Serial.print(F("Security level: "));
Serial.println(finger.security_level);
Serial.print(F("Device address: "));
Serial.println(finger.device_addr, HEX);
Serial.print(F("Packet len: "));
Serial.println(finger.packet_len);
Serial.print(F("Baud rate: "));
Serial.println(finger.baud_rate);
lcd.init();
lcd.backlight();
uint8_t readnumber(void) {
uint8_t num = 0;
while (num == 0) {
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Insert (1 to 10)");
lcd.setCursor(0, 1);
lcd.print("To save");
Serial.println(num);
char key = keypad.getKey();
if (key >= '0' && key <= '9') // it's a digit
num = num * 10 + (key - '0');
else if (key == '>') {
// step clockwise
num = 0; // Once the stepper has stepped, reset Value back to zero.
else if (key == '<') {
// step C-clockwise
return num;
uint8_t readnumber2(void) {
uint8_t num = 0;
while (num == 0) {
lcd.clear();
lcd.print("To delete");
// step clockwise
// step C-clockwise
return num;
Serial.println(Value);
while (Value == 1) {
Serial.println(v_passcode);
lcd.clear();
if (key != NO_KEY) {
Serial.println("Ini didalem");
//Serial.println(key);
v_passcode = v_passcode + key;
if (key == 'D') {
Serial.println("Validate the Password");
if (v_passcode == pass) {
Serial.println("Access Granted");
lcd.setCursor(1, 0);
lcd.print("1. Enroll");
lcd.setCursor(1, 1);
lcd.print("2. Delete ->");
Trig = Trig + 1;
Serial.println(Trig);
v_passcode = "";
while (Trig == 1) {
if (key == 'A') {
Trig = 0;
if (key == 'H') {
lcd.clear();
lcd.print("3. Set Password");
lcd.print(" <-");
if (key == 'S') {
lcd.clear();
if (key == '1') {
lcd.clear();
Serial.println("Ready to enroll a fingerprint!");
Serial.println("Please type in the ID # (from 1 to 127) you want to save this finger as...");
id = readnumber();
if (id == 0) { // ID #0 not allowed, try again!
return;
Serial.print("Enrolling ID #");
Serial.println(id);
while (!getFingerprintEnroll())
Serial.println(id);
Trig = 0;
} else if (key == '2') {
Serial.println("Please type in the ID # (from 1 to 127) you want to delete...");
uint8_t id = readnumber2();
return;
Serial.print("Deleting ID #");
Serial.println(id);
deleteFingerprint(id);
Trig = 0;
} else if (key == '3') {
lcd.clear();
Trig2 = Trig2 + 1;
lcd.print("Input Password");
while (Trig2 == 1) {
pass = v_passcode;
lcd.clear();
lcd.print(v_passcode);
if (key == 'A') {
lcd.clear();
v_passcode = "";
if (key == 'D') {
lcd.print("Password Set!");
Trig2 = 0;
Trig = 0;
pass != "000D";
v_passcode = "";
else {
Serial.println("Access Denied");
v_passcode = "";
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
if (key) {
Value = 1;
Serial.println("No finger detected");
return p;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
return p;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
return p;
default:
Serial.println("Unknown error");
return p;
// OK success!
p = finger.image2Tz();
switch (p) {
Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// OK converted!
p = finger.fingerSearch();
if (p == FINGERPRINT_OK) {
Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_NOTFOUND) {
Serial.println("Did not find a match");
return p;
return p;
// found a match!
Serial.print("Found ID #");
Serial.print(finger.fingerID);
Serial.print(" with confidence of ");
Serial.println(finger.confidence);
return finger.fingerID;
int getFingerprintIDez() {
if (p != FINGERPRINT_OK) return -1;
p = finger.fingerFastSearch();
// found a match!
uint8_t deleteFingerprint(uint8_t id) {
uint8_t p = -1;
p = finger.deleteModel(id);
lcd.clear();
lcd.print("Deleted!");
Serial.println("Deleted!");
lcd.clear();
Value = 0;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not delete in that location");
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
Serial.print("Unknown error: 0x");
Serial.println(p, HEX);
return p;
uint8_t getFingerprintEnroll() {
int p = -1;
lcd.clear();
lcd.print("Place your");
lcd.print("finger");
Serial.print("Waiting for valid finger to enroll as #");
Serial.println(id);
while (p != FINGERPRINT_OK) {
switch (p) {
Serial.println(".");
default:
// OK success!
p = finger.image2Tz(1);
switch (p) {
return p;
return p;
lcd.clear();
lcd.print("Error");
return p;
lcd.clear();
lcd.print("Error");
return p;
default:
return p;
lcd.clear();
lcd.print("Remove Finger");
Serial.println("Remove finger");
delay(2000);
lcd.clear();
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID ");
Serial.println(id);
p = -1;
lcd.clear();
lcd.print("Place same");
lcd.print("finger again");
Serial.println("Place same finger again");
switch (p) {
Serial.print(".");
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
return p;
return p;
lcd.clear();
lcd.print("Error");
return p;
lcd.clear();
lcd.print("Error");
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #");
Serial.println(id);
p = finger.createModel();
Serial.println("Prints matched!");
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
lcd.clear();
lcd.print("Failed!");
Serial.println("Fingerprints did not match");
return p;
return p;
Serial.println(id);
p = finger.storeModel(id);
lcd.clear();
lcd.print("Done!");
delay(2000);
lcd.clear();
Serial.println("Stored!");
Value = 0;
return p;
Serial.println("Could not store in that location");
return p;
return p;
return p;
return true;
