I need some help with HID keyboard code
uint8_t buf[8] = {0}; // Keyboard Report Buffer: 8 bytes
#define PIN_a 13
#define PIN_s 12
#define PIN_d 11
#define L_Shift 10
#define PIN_j 9
#define PIN_k 8
#define PIN_l 7
#define R_Shift 6
//#define SERIAL_DEBUG // for serial debug: remove //
// for actual HID: put //
bool currState_PIN_a = HIGH;
bool currState_PIN_s = HIGH;
bool currState_PIN_d = HIGH;
bool currState_L_Shift = HIGH;
bool currState_PIN_j = HIGH;
bool currState_PIN_k = HIGH;
bool currState_PIN_l = HIGH;
bool currState_R_Shift = HIGH;
bool prevState_a = HIGH;
bool prevState_s = HIGH;
bool prevState_d = HIGH;
bool prevState_L_Shift = HIGH;
bool prevState_j = HIGH;
bool prevState_k = HIGH;
bool prevState_l = HIGH;
bool prevState_R_Shift = HIGH;
unsigned long prevTime_a = 0;
unsigned long prevTime_s = 0;
unsigned long prevTime_d = 0;
unsigned long prevTime_L_Shift = 0;
unsigned long prevTime_j = 0;
unsigned long prevTime_k = 0;
unsigned long prevTime_l = 0;
unsigned long prevTime_R_Shift = 0;
unsigned long waitTime_a = 50;
unsigned long waitTime_s = 50;
unsigned long waitTime_d = 50;
unsigned long waitTime_L_Shift = 50;
unsigned long waitTime_j = 50;
unsigned long waitTime_k = 50;
unsigned long waitTime_l = 50;
unsigned long waitTime_R_Shift = 50;
pinMode(PIN_a, INPUT_PULLUP);
pinMode(PIN_s, INPUT_PULLUP);
pinMode(PIN_d, INPUT_PULLUP);
pinMode(L_Shift, INPUT_PULLUP);
pinMode(PIN_j, INPUT_PULLUP);
pinMode(PIN_k, INPUT_PULLUP);
pinMode(PIN_l, INPUT_PULLUP);
pinMode(R_Shift, INPUT_PULLUP);
delay(200);
checkButton();
void checkButton() {
bool currRead_a = digitalRead(PIN_a);
bool currRead_s = digitalRead(PIN_s);
bool currRead_d = digitalRead(PIN_d);
bool currRead_L_Shift = digitalRead(L_Shift);
bool currRead_j = digitalRead(PIN_j);
bool currRead_k = digitalRead(PIN_k);
bool currRead_l = digitalRead(PIN_l);
bool currRead_R_Shift = digitalRead(R_Shift);
if (currRead_a != prevState_a) {
prevTime_a = millis();
if (currRead_s != prevState_s) {
prevTime_s = millis();
if (currRead_d != prevState_d) {
prevTime_d = millis();
if (currRead_L_Shift != prevState_L_Shift) {
prevTime_L_Shift = millis();
if (currRead_j != prevState_j) {
if (currRead_k != prevState_k) {
if (currRead_l != prevState_l) {
if (currRead_R_Shift != prevState_R_Shift) {
if ((millis() - prevTime_a) > waitTime_a) {
if (currRead_a != currState_PIN_a) {
currState_PIN_a = currRead_a;
if (currState_PIN_a == LOW) {
// Send the code
buf[2] = 4; // HID: a key
#ifdef SERIAL_DEBUG
buf[2] = 'a'; // Serial: a key
#endif
Serial.write(buf, 8); // Send keypress
// Release the keyboard
releaseKey();
if ((millis() - prevTime_s) > waitTime_s) {
if (currRead_s != currState_PIN_s) {
currState_PIN_s = currRead_s;
if (currState_PIN_s == LOW) {
// Send the code
buf[2] = 22; // HID: s key
#ifdef SERIAL_DEBUG
buf[2] = 's'; // Serial: A key
#endif
releaseKey();
if ((millis() - prevTime_d) > waitTime_d) {
if (currRead_d != currState_PIN_d) {
currState_PIN_d = currRead_d;
if (currState_PIN_d == LOW) {
// Send the code
buf[2] = 7; // HID: d key
#ifdef SERIAL_DEBUG
buf[2] = 'd'; // Serial: d key
#endif
releaseKey();
if ((millis() - prevTime_L_Shift) > waitTime_L_Shift) {
if (currRead_L_Shift != currState_L_Shift) {
currState_L_Shift = currRead_L_Shift;
if (currState_L_Shift == LOW) {
// Send the code
buf[2] = 225; // HID: L_Shift key
#ifdef SERIAL_DEBUG
buf[2] = 'L'; // Serial: L_Shift key
#endif
releaseKey();
if ((millis() - prevTime_j) > waitTime_j) {
if (currRead_j != currState_PIN_j) {
currState_PIN_j = currRead_j;
if (currState_PIN_j == LOW) {
// Send the code
buf[2] = 13; // HID: j key
#ifdef SERIAL_DEBUG
buf[2] = 'j'; // Serial: j key
#endif
releaseKey();
if ((millis() - prevTime_k) > waitTime_k) {
if (currRead_k != currState_PIN_k) {
currState_PIN_k = currRead_k;
if (currState_PIN_k == LOW) {
// Send the code
buf[2] = 14; // HID: k key
#ifdef SERIAL_DEBUG
buf[2] = 'k'; // Serial: k key
#endif
releaseKey();
if ((millis() - prevTime_l) > waitTime_l) {
if (currRead_l != currState_PIN_l) {
currState_PIN_l = currRead_l;
if (currState_PIN_l == LOW) {
// Send the code
buf[2] = 15; // HID: l key
#ifdef SERIAL_DEBUG
buf[2] = 'l'; // Serial: l key
#endif
releaseKey();
if ((millis() - prevTime_R_Shift) > waitTime_R_Shift) {
if (currRead_R_Shift != currState_R_Shift) {
currState_R_Shift = currRead_R_Shift;
if (currState_R_Shift == LOW) {
// Send the code
buf[2] = 229; // HID: R_Shift key
#ifdef SERIAL_DEBUG
buf[2] = 'R'; // Serial: R_Shift key
#endif
releaseKey();
prevState_a = currRead_a;
prevState_s = currRead_s;
prevState_d = currRead_d;
prevState_L_Shift = currRead_L_Shift;
prevState_j = currRead_j;
prevState_k = currRead_k;
prevState_l = currRead_l;
prevState_R_Shift = currRead_R_Shift;
void releaseKey()
buf[0] = 0;
buf[2] = 0;
Serial.write(buf, 8); // Release key
I'm using arduino uno R3 as a keyboard(controller).
A, S, D, L_Shift keys work fine. They work how I want.
But, J, K, L, R_Shift keys don't work same as A, S, D, L_Shift keys.
J, K, L, R_Shift sends several signals like chattering. And I don't understand why this is happening.
How should I fix the code??
Welcome,
Please edit your post and put your code inside a code box
Your problem is here :
It wouldn't have happened if you used arrays and for loops, instead of duplicating the code for each key :slight_smile:
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
See how much shorter the code gets when you use arrays and some simple loops.
const byte Count = 8;
byte buf[8]; // Keyboard Report Buffer: 8 bytes
const char *KeyNames[Count] = {"a", "s", "d", "LeftShift", "j", "k", "l", "RightShift"};
const byte Pins[Count] = {13, 12, 11, 10, 9, 8, 7, 6};
const byte KeyValue[Count] = {4, 22, 7, 225, 13, 14, 15, 229};
bool CurrState[Count] = {HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH};
bool PrevState[Count] = {HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH, HIGH};
unsigned long PrevTime[Count];
const unsigned long WaitTime = 50;
  delay(200);
  for (byte k = 0; k < Count; k++)
    pinMode(Pins[k], INPUT_PULLUP);
    bool currRead = digitalRead(Pins[k]);
    if (currRead != PrevState[k])
      PrevTime[k] = millis();
    if ((millis() - PrevTime[k]) > WaitTime)
      if (currRead != CurrState[k])
        CurrState[k] = currRead;
        if (CurrState[k] == LOW)
#ifdef SERIAL_DEBUG
          Serial.print(KeyNames[k]);
#else
          // Send the code
          buf[2] = KeyValue[k]; // HID: a key
#endif
#ifdef SERIAL_DEBUG
          Serial.println(" Release");
#else
          releaseKey();
#endif
    PrevState[k] = currRead;
void releaseKey()
  buf[0] = 0;
  buf[2] = 0;
