I need some help with my code i cant find what is wrong with my code
So i am under 13 and i need some help coding here is my code
#define STEPPER_PIN_1 9
#define STEPPER_PIN_2 10
#define STEPPER_PIN_3 11
#define STEPPER_PIN_4 12
int step_number = 0;
pinMode(STEPPER_PIN_1, OUTPUT);
pinMode(STEPPER_PIN_2, OUTPUT);
pinMode(STEPPER_PIN_3, OUTPUT);
pinMode(STEPPER_PIN_4, OUTPUT);
OneStep(false);
delay(2);
void OneStep(bool dir){
if(dir){
switch(step_number){
case 0:
digitalWrite(STEPPER_PIN_1, HIGH);
digitalWrite(STEPPER_PIN_2, LOW);
digitalWrite(STEPPER_PIN_3, LOW);
digitalWrite(STEPPER_PIN_4, LOW);
case 1:
digitalWrite(STEPPER_PIN_1, LOW);
digitalWrite(STEPPER_PIN_2, HIGH);
case 2:
digitalWrite(STEPPER_PIN_3, HIGH);
case 3:
digitalWrite(STEPPER_PIN_4, HIGH);
}else{
case 0:
case 1:
case 2:
case 3:
case 4:
step_number;
if(step_number > 3){
step_number = 0;
here is my error code
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Uno"
Auto_clicker_prototype:50:3: error: expected unqualified-id before 'else'
}else{
exit status 1
option enabled in File -> Preferences.
i need help on fixing it.
Hello sleepybuzzard551
Here comes a free forum service and next time post the sketch formatted and commented. This will help better in troubleshooting.
Just check the placement of the "{}" brackets.
  OneStep(false);
  delay(2);
void OneStep(bool dir) {
  if (dir) {
    switch (step_number) {
      case 0:
      case 1:
      case 2:
      case 3:
    case 0:
    case 1:
    case 2:
    case 3:
    case 4:
  step_number;
  if (step_number > 3) {
    step_number = 0;
Have a nice day and enjoy programming in C++ and learning.
MIND THE GAP
should be
else {
Hi @sleepybuzzard551
the error-message has two numbers separated by a double-point ":"
This tells you where in your the error occurred
line 50 columm 3
and then the line is quoted
}else{
In this line is the error
You should press Ctrl-T each time before you compile new
This will autoformat your code with indentions
indent to the right for each opening curly brace "{"
indent to the left for each closing curly brace "}"
if the indention of a line is most left and some more code is following below that belongs to the same function there is a too much closing curly brace like in your case
      case 3:
the closing curly brace left of "else" is at the wrong place
it should be below all code belonging to function "onestep()"
There is already a "final closing" curly brace
      case 3:
 else { // <==== REMOVED closing curly brace
you should re-edit your first posting by following this manual
best regards Stefan
Hi, @sleepybuzzard551
Welcome to the forum.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
For future reference, "expected unqualified-id before" is one of the errors commonly caused by mismatched brackets. Here is a list of such errors to study.
Common compiler errors caused by mismatched brackets:
"does not name a type" or
"expected declaration before" or
"expected unqualified-id before" or
"expected initializer before" or
"expected constructor, destructor, or type conversion before '(' token"
Usually means you forgot a '{' or put in an extra '}' in the previous function. Since all of the open brackets have been closed, the compiler is looking for further global declarations (variables or functions). If it finds something that looks like executable code instead of a global declaration it emits an error. Make sure that the brackets in the preceding function are in matching pairs '{' followed by '}'.
"a function-definition is not allowed here before '{' token"
(can cause: "'functionName' was not declared in this scope")
Usually means you forgot a '}' or put in an extra '{' in the previous function. Since a set of brackets has not been closed yet the compiler is looking for more code to put in the function. You can't declare a function inside a function so if the compiler finds a function declaration it emits an error. Make sure that the brackets in the preceding function are in matching pairs '{' followed by '}'.
"expected '}' at end of input"
Usually means you forgot a '}' or put in an extra '{' in the last function in the sketch. Since a set of brackets has not been closed yet, the compiler is looking for more code to put in the function. When it hits the end of the file instead, it emits an error. Make sure that the brackets in the last function are in matching pairs '{' followed by '}'.
"expected primary-expression before '}' token"
Usually means you have an incomplete statement before a '}'. The block statement (between '{' and matching '}') can only contain complete statements. Complete statements always end with ';' (or '}' for a block statement).
I got it to work! Thanks guys!
Can you please post your working code, so anyone else looking with a similar problem can see your solution?
Thanks.. Tim.... :smiley: :+1: :coffee: :australia:
