Hi I need you help
I just followed steps in this video How to make Smart Dustbin with Arduino | Arduino Project - YouTube
but the results my servo motor does not stop rotate it always rotate till I disconnect the power
Dustbin.ino (1.12 KB)
Hi I need you help
Can you try this code and let me know if this works.
#include <Servo.h> // Servo library
Servo myServo; // Change Name Accordingly
int trigPin = 2; // Change Pin Accordingly
int echoPin = 3; // Change Pin Accordingly
int servoPin = 4; // Change Pin Accordingly
int led = 5; // Change Pin Accordingly
long duration, distance;
//Serial.begin(9600); //For Troubleshooting
myServo.attach(servoPin);
pinMode(trigPin, OUTPUT); // Declare Trigger Pin as Output
pinMode(echoPin, INPUT); // Declare Echo Pin as Input
servo.write(0);
digitalWrite(led, HIGH);
digitalWrite(trigPin, LOW);
delayMicroseconds(5);
digitalWrite(trigPin, HIGH);
delayMicroseconds(20);
duration = pulseIn(echoPin, HIGH);
dist = duration * 0.034 / 2; //Measure Distance
if (dist < 100) { // Change Distance Value Accordingly
myServo.write(150); // Change Degree Value Accordingly
delay(5000); // 5 sec Delay, //Change Accordingly
myServo.write(0);
//Serial.println(dist); //For Troubleshooting
What type of servo do you have ?
Is it by any chance a "continuous rotation servo" ?
