I need to create a tensioning system for a prosthetic device.
Is Arduino something that could power a gear or wheel with a cable or cord attached to it. It would need to be small, deliver torque and have slow rpm's. Thank you for your time in advance.
It could command a servo with the needed performance easily enough.
Note that you used the word "power" and Crossroads answered using the word "command" because the arduino is uController , not a power supply and as he stated, it is capable of controlling motor/servo systems that are powered from an alternate power source.
(such as a battery, possibly Lipo but not necessarily)
So, Arduino is a programmable circuit board that could control a motor that was powered by a battery, correct? Would it be able to communicate with a software app or remote control of some sort? I am looking to create a way to control a small motor in a device that is worn under clothing. Once again, thanks in advance for your time.
No, to control a motor you need an h-bridge to drive current in 2 directions in the motor.
Arduino can control the h-bridge.
Servo is another kind of motor with the controller built in.
Yes, arduino has communication capability, to another device via wires, or via RF with the addition of a bluetooth module for example.
teamLIM:
Start by picking the motor/servo that you want to control. A servo will be much easier to control than a DC motor since it contains all the related driver electronics and gives you direct positional control (or direct speed control, with modification).
Thank you for your insight. I will research "servos" and mini motors and return for advice once i decide which device i will be using. This is exciting.
You might need a linear actuator.
If you want a tensioner then you would need a geared motor assembly that can generate some torque.
A mechanical drawing might help.
