I need to mesure a door position & to control the door lock (too)
hello,
I need to know if the door is open or not.
Easy with a button.
But at the same time, I need to control the door lock system.
It requires 12v and it only need a little current.
I only need to send 12v for 200ms, and the door lock opens itself.
This part work manually but I need to control it from an arduino via Max5
A guy told me to use a relay to supply the door lock with my
I thought I could use "only" a transistor BD135-like.
So here are my questions:
  • I read http://itp.nyu.edu/physcomp/Tutorials/HighCurrentLoads & other schemas, but I cannot find the right wiring for me.
    could someone make it for me ?
  • Do I really need a relay? or does this transistor could be enough?
  • I would like to send a particular bytes ("o" for open..) from Max5 patch to Arduino and I'd like the arduino to compare the bytes received to a value constantly.
    here is my sketch:
  // send data only when you receive data:
	if (Serial.available() > 0) {
			digitalWrite(doorlockPin, HIGH) ;
			digitalWrite(doorlockPin, LOW) ;
                        Serial.flush();
        else digitalWrite(doorlockPin, LOW) ;
The Serial.flush() is here because without it, the Serial.available is everytime >0 after the first byte sent.
I did that because Serial.read() results in a pointer and I cannot compare it...
Could someone help me with that ?
I'm finishing this last system for the museum I'm working with.
It would be so sweet to have some answers.
best,
No, a transistor or FET will work.
The concept of "little" in not very accurate, I bet it needs a whole whack of current from the arduino perspective. You need to know how much.
I read Lab: Using a Transistor to Control High Current Loads with an Arduino – ITP Physical Computing &
My totally unfravroutiest web site, it tries but ultimately it is rubbish.
Look here:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
for both relay drivers and direct transistors.
That is because you don't read anything.
No it doesn't it is an ASCII character
val = Serial.read();
if(val == 'o') { digitalWrite(doorLockPin, HIGH); ........
Note the single quote not a double one.
the main problems were:
  • the single quote
  • the circuit to supply the door lock
thanks a lot, all works fine now :slight_smile:
I'd probably explain all the project here or there, feel free to keep in touch on http://designthemedia.com
