How have you got it wired up, please supply a proper schematic.
Have you looked at the data sheet for the transmitter? What voltage are you powering it with.
You can also set a pin as an output, outputting a logic zero. Then make it into an input and pull the pin to what ever voltage you want ( up to the power supply of the Arduino*) with a pull up resistor to the voltage powering the transmitter.
that is the power supply of the chip not the voltage applied to an internal regulator.
Hi Roy,
If you are wiring the transmitter to 5V then there will be no issue in sending it 5V on the pins. So no need to do that trick, just wire it straight.
