goodnight I am doing a project of surge with an autotransformer
As you vary the voltage supplied by the mains of my country varies its output
this is by sensing voltage across a control winding of the autotransformer whose readings are 2.5v - 4v
which I am by sensing in the analog pin A0
I need to know that voltage sensing that enable power stage and thus achieve steady output voltage to 120 VAC 60Hz
when making my design to detect apply the following arrangement
a bridge rectifier and a capacitor and a variable resistor
one pin connected to Vcc
pin center to pin analog A0
and the last to GND
pero no me percate del tiempo que le toma al capacitor de carga y descarga
which at the time of the readings by analogRead the capacitor discharge time is outside the parameters set
my question is
as I can read this voltage
since my Arduino UNO reads 0 - 5V
which it is the same from 0-255
thank you very much
