I need to Read upto 100v Dc battery voltage. (via arduino)
Hello,
I need to ready DC battery voltages but they are connected in series and make upto 100 volts and the batteries are 200 amp/hour each.
I need help here please guide me to a safe and accurate way to read these voltages.
Regards
A good multimeter will easily handle this.
Make sure you set it to read DC voltages.
Via Arduino Man
http://www.ohmslawcalculator.com/voltage-divider-calculator
Idahowalker:
will it not heat-up because of the high amps of the battery ?
I assume you understand how to [u]Read Analog Voltage[/u] up to 5V?
Use a [u]Voltage Divider[/u] (2 resistors) to knock-down the voltage. The resistor values should probably sum-up to around 100K Ohms so they don't consume too much power and overheat.
Current (Amps) = Voltage/Resistance (Ohm's Law). That's the current through the resistors. (You can have additional current flowing through other circuitry at the same time.)
And power (Watts) = Voltage x Current.
Umair78:
