I see cryptic red "avrdude" text when I upload
I would need some help
Sketch uses 6600 bytes (20%) of program storage space. Maximum is 32256 bytes.
Global variables use 261 bytes (12%) of dynamic memory, leaving 1787 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex"
avrdude: writing flash (6600 bytes):
Writing | ################################################## | 100% 1.48s
avrdude: 6600 bytes of flash written
avrdude: verifying flash memory against C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex:
avrdude: load data flash data from input file C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex:
avrdude: input file C:\Users\arsalan\AppData\Local\Temp\arduino_build_304362/DumpInfo.ino.hex contains 6600 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.95s
avrdude: verifying ...
avrdude: 6600 bytes of flash verified
avrdude done. Thank you.
cnar5:
The output you posted shows a successful compilation and upload. Everything is working fine. Carry on.
Sketch uses 1986 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 50 bytes (2%) of dynamic memory, leaving 1998 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\arduino-1.8.13\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\arduino-1.8.13\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\FB~BES~1\AppData\Local\Temp\arduino_build_149579/Servo_dan_LDR.ino.hex:i
avrdude: Version 6.3-20190619
System wide configuration file is "C:\Program Files (x86)\arduino-1.8.13\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
Reading | ################################################## | 100% 0.00s
avrdude: reading input file "C:\Users\FB~BES~1\AppData\Local\Temp\arduino_build_149579/Servo_dan_LDR.ino.hex"
avrdude: writing flash (1986 bytes):
Writing | ################################################## | 100% 0.33s
avrdude: 1986 bytes of flash written
avrdude: verifying flash memory against C:\Users\FB~BES~1\AppData\Local\Temp\arduino_build_149579/Servo_dan_LDR.ino.hex:
avrdude: load data flash data from input file C:\Users\FB~BES~1\AppData\Local\Temp\arduino_build_149579/Servo_dan_LDR.ino.hex:
avrdude: input file C:\Users\FB~BES~1\AppData\Local\Temp\arduino_build_149579/Servo_dan_LDR.ino.hex contains 1986 bytes
Reading | ################################################## | 100% 0.26s
avrdude: 1986 bytes of flash verified
ramania:
You have posted the output from a successful upload. Congratulations! Enjoy your fun and learning with Arduino.
