I share with you a project for light lamp with a light sensor
int readPin = A0;
int readValue;
int redPin = 3;
int void setup() {
pinMode(readPin, INPUT);
pinMode(redPin, OUTPUT);
readValue = analogRead(readPin);
if (readValue < 920) {
digitalWrite(redPin, HIGH);
digitalWrite(redPin, LOW);
Serial.println(readValue);
This is not correct. The standard is void setup()
Also, please, format your code and re-post your code using the < CODE > button in the message box... the result should look like this...
int readPin = A0;
int readValue;
int redPin = 3;
// int void setup() { // no!
void setup() { // yes!
Hello, do yourself a favour and please read How to get the best out of this forum and post accordingly (including code with code tags).
Do you have a question or you felt happy with the code and wanted to just share?
Hi, @polis_12
How many projects do you have going?
Have you not learnt how to post code by now?
And in none of them have you reponded?
Tom.. :smiley: :+1: :coffee: :australia:
nor has he/she fixed the code tags...
another entry in the ignore list soon...
OP Just invented the wheel .... again.
OP also continues to publish in "Uncategorized." (category later changed, not by OP) Would an unresponsive user be treated as a bot (is there a provision in the rules)?
Indeed s/he has 3 dumb posts... seems like a bot...
I'll report to moderation.
