I'm currently developing a project which makes use of Parent Classes and Child Classes. I've been developing the code for about a year now, and have learned quite a lot along the way.
I'm creating many different types of child classes that all inherit from the Parent Class. All of these classes do different things. The main reason for inheriting from the parent class is so that I may store all the different objects in a container of type "Parent Class". This makes referencing the objects in runtime later on quite simple.
This has been working very well for me so far, until this point. I'm starting to develop child classes that use templates. The problem arises when I try to override a member function that's job is to return something with the template type. This causes an error (as expected) because there is no covariance between the overridden child class return type and the virtual function return type.
For those of you who understand this problem, may you please suggest an alternative approach? Or some other way of thinking about this problem that may help me solve it?
For those of you who are confused, I'd be happy to provide more information. At this point I'm not providing any code examples, just because I believe my question is more conceptual, rather than syntactical.
FYI, I'm programming the Raspberry PI Pico with Arduino IDE 2.1.0
Below is an example of my current class structure, that reproduces there error. Let me know if this helps. Any thoughts are appreciated.
Sincerely,
Marcus G
#include <map>
#include <memory>
class Module
public:
enum class moduleType{
TYPE_DATA_ARRAY
int getAddress() {return m_address; }
int getID() {return m_ID; }
moduleType getModuleType() {return m_moduleType; }
// Configures the class to run for the first time. Only run once, after instantiating the class object.
virtual int configure()
return -1;
virtual void process()
virtual int getBufferValue(int index)
return -1;
virtual void* getBufferPointer()
return nullptr;
protected:
const int m_address;
int m_ID;
const moduleType m_moduleType;
Module(int address, moduleType moduleType)
:m_address{address}, m_moduleType{moduleType}
if(m_addressIdMap.find(address) != m_addressIdMap.end())
m_ID = m_addressIdMap.at(address);
m_addressIdMap.at(address)++;
m_ID = 0;
m_addressIdMap[address] = 1;
private:
static int newUID;
static std::map<int,int> m_addressIdMap;
int Module::newUID = 0;
std::map<int, int> Module::m_addressIdMap = {};
template<typename T>
class DataArray : public Module
private:
T* m_Buffer;
int m_length;
public:
DataArray(int address, int length)
:Module{address, moduleType::TYPE_DATA_ARRAY},
m_length{length}
m_Buffer = new T[length];
~DataArray()
delete [] m_Buffer;
int getBufferValue(int index) override {return m_Buffer[index];}
T* getBufferPointer() override
return m_Buffer;
void process() override
std::shared_ptr<Module> da = std::make_shared<DataArray<volatile uint8_t>> (0, 100);
Thanks so much for the response. This information is very helpful. Now I am stuck at the next step, which is actually using this object. There are two options I see, both result in similar errors. Is there a smarter way of doing this?
See code snippet below. There are two "options" in the setup() function that will reproduce the new errors.
Option 1 error: Compilation error: 'void*' is not a pointer-to-object type
Option 2 error: Compilation error: invalid conversion from 'void*' to 'uint8_t*' {aka 'unsigned char*'} [-fpermissive]
#include <map>
#include <memory>
class Module {
public:
enum class moduleType {
TYPE_DATA_ARRAY
int getAddress() {
return m_address;
int getID() {
return m_ID;
virtual int configure() {
return -1;
virtual void process() {
virtual int getBufferValue(int index) {
return -1;
virtual void* getBufferPointer() {
return nullptr;
protected:
int m_ID;
: m_address{address}, m_moduleType{moduleType} {
if (m_addressIdMap.find(address) != m_addressIdMap.end()) {
m_ID = 0;
private:
static int newUID;
static std::map<int, int> m_addressIdMap;
class DataArray : public Module {
private:
T *m_Buffer;
int m_length;
public:
: Module{address, moduleType::TYPE_DATA_ARRAY},
m_length{length} {
~DataArray() {
delete [] m_Buffer;
//T* getBufferPointer() override {
void *getBufferPointer() override {
return m_Buffer;
void process() override {
//std::shared_ptr<Module> da = std::make_shared<DataArray<volatile uint8_t>> (0, 100);
std::shared_ptr<Module> da = std::make_shared<DataArray<uint8_t>> (0, 100);
//option 1:
auto dataptr = da.get()->getBufferPointer();
uint8_t value = dataptr[0];
//option 2:
//uint8_t* dataptr = da.get()->getBufferPointer();
My only concern is if this is the best approach for this kind of task? I feel like it could be dangerous to be using casting in general, as well as void pointers and whatnot. So I'm just wondering if there are any other concepts I could be looking at to make this more robust.
I understand not having a clear understanding of the point of all this would be frustrating.
Basically, I’m developing a feature set that will be designed ahead of time (now), but the actual use and deployment will be set up at run time across many distributed units all networked together. I’d like a container to store representations of these “features” on each unit so that the main loop can cycle through each one and process them one by one.
There must be a design pattern for something this already, but haven’t discovered one yet.
What I have now, and using the casting does seem to work well. I’m sure I’ll come across some more issues soon though
Curious why you chose the reinterpret_cast rather than a static_cast?
