I tried making a pokeball image with my oled and it worked the first time with my code but not 2nd, pls help :(
I tried making a pokeball image with my oled and it worked the first time with my code however when I answered correctly first of all it didnt pop up on lcd, at the same time oled didnt show anything either, however the wiring is fine and other image examples such as heart worked fine to be used multiple times. I tried asking chat gpt for help but it destroyed my image. Can I have some help please?
This code is supposed to be a spell checking device for kids to type letters on a keypad and check for spelling thus learn. The way it should work is you type your word with letters , it spell checks the word and you get a "incorrect!" or a "correct!" then you try again. there are a few parts which are plans for newer features i will soon add. It also displays the image of the word on the OLED and you type words that appear in the LCD screen.
here is the code:
#include <Wire.h>
#include <SparkFun_Qwiic_Keypad_Arduino_Library.h>
#include <SparkFun_Qwiic_OLED.h> // Include the SparkFun Qwiic OLED library
const int mercurySwitchPin = 2;  // Replace with the actual pin number where the switch is connected
int Mercury = 0;
#include <SerLCD.h>
SerLCD lcd;
// Initialize TwoWire objects for two keypads
TwoWire Wire1;
TwoWire Wire2;
// Initialize keypad objects
KEYPAD keypad1;
KEYPAD keypad2;
// Variables to hold the current state
String finalString = "";
boolean startMessageShown = false;
// List of words for the game
String words[] = {/*"smile","circle","triangle","rectangle","diamond","square","heart",*/"heart"}; //smile","circle","triangle","rectangle","diamond", //{"smile","circle","triangle","rectangle","diamond","square","heart"};
int arraySize = sizeof(words) / sizeof(words[0]);
String currentWord;
// Declare width and height as global variables
int width;
int height;
int index;
// Mapping for keypad 1
char keypad1Mapping[4][3] = {
{'a', 'b', 'c'},
{'d', 'e', 'f'},
{'g', 'h', 'i'},
{'*', 'j', 'k'}
// Mapping for keypad 2
char keypad2Mapping[4][3] = {
{'l', 'm', 'n'},
{'o', 'p', 'q'},
{'r', 's', 't'},
{'u', 'v', '#'}
// Enum to represent the game state
enum GameState {
WAIT_FOR_START,
IN_GAME,
WAIT_FOR_RESTART
// Initialize game state
GameState currentState = WAIT_FOR_START;
QwiicMicroOLED myOLED; // Create an instance of the Qwiic Micro OLED object
void setup(void) {
   pinMode(mercurySwitchPin, INPUT);  // Set the pin as an input
Serial.begin(9600); // Initialize serial communication
lcd.begin(Wire);
lcd.clear();
Wire1.begin();
Wire2.begin();
// Check if keypads are connected
if (keypad1.begin(Wire1, 0x4B) == false || keypad2.begin(Wire2, 0x2A) == false) {
Serial.println("One or both keypads do not appear to be connected. Please check wiring. Freezing...");
while (1);
// Initialize the OLED device and related graphics system
if (myOLED.begin() == false) {
Serial.println("Device begin failed. Freezing...");
while (1);
// Save device dims for the test routines
width = myOLED.getWidth();
height = myOLED.getHeight();
// Seed the random number generator
randomSeed(analogRead(0));
Serial.println("Initial analogRead(0): " + String(analogRead(0)));
Serial.println("Array Size: " + String(arraySize));
int randomIndex = random(arraySize);
Serial.println("Random Index: " + String(randomIndex));
int generateRandomIndex(int arraySize) {
long seed = 0;
for (int i = 0; i < 32; i++) {
seed ^= long(analogRead(0)) << i;
delay(1);
randomSeed(seed);
return randomIndex;
// Function to draw a circle
  void drawCircle(int width, int height) {
  myOLED.circle(width / 2, height / 2, height / 4); // Center at (width/2, height/2) with radius height/4
void drawPokeBall(int width, int height) {
  int circleCenterX = width / 2;
  int circleCenterY = height / 2;
  int circleRadius = height / 4;
  int pixelOffRadius = width / 15;
  int offsetY = 1;
  myOLED.circle(circleCenterX, circleCenterY, circleRadius);
  int x1 = circleCenterX - circleRadius;
  int x2 = circleCenterX + circleRadius;
  int y = circleCenterY + offsetY;
  int y2 = circleCenterY - offsetY;
  myOLED.line(x1, y, x2, y);
  myOLED.line(x1, y2, x2, y2);
  int radius = width / 12;
  for (int y3 = -radius; y3 <= radius; y3++) {
    for (int x3 = -radius; x3 <= radius; x3++) {
      if (x3 * x3 + y3 * y3 <= radius * radius) {
        myOLED.pixel(circleCenterX + x3, circleCenterY + y3);
  int radius3 = width / 14;
  for (int y5 = -radius3; y5 <= radius3; y5++) {
    for (int x5 = -radius3; x5 <= radius3; x5++) {
      if (x5 * x5 + y5 * y5 <= radius3 * radius3) {
        myOLED.pixel(circleCenterX + x5, circleCenterY + y5);
  for (int y6 = -pixelOffRadius; y6 <= pixelOffRadius; y6++) {
    for (int x6 = -pixelOffRadius; x6 <= pixelOffRadius; x6++) {
      if (x6 * x6 + y6 * y6 <= pixelOffRadius * pixelOffRadius) {
        myOLED.pixel(circleCenterX + x6, circleCenterY + y6, false);
  int radius4 = width / 19;
  for (int y6 = -radius4; y6 <= radius4; y6++) {
    for (int x6 = -radius4; x6 <= radius4; x6++) {
      if (x6 * x6 + y6 * y6 <= radius4 * radius4) {
        myOLED.pixel(circleCenterX + x6, circleCenterY + y6);
// Function to draw a square
  void drawSquare(int width, int height) {
  int sideLength = min(width, height) / 2; // Ensure the square fits within the screen
  int x = width / 2 - sideLength / 2;
  int y = height / 2 - sideLength / 2;
  myOLED.rectangle(x, y, sideLength, sideLength); // Top-left corner at (x, y) with side length 'sideLength'
// Function to draw a rectangle
    void drawRectangle(int width, int height) {
    myOLED.rectangle(width / 4, height / 4, width / 2, height / 4); // Top-left corner at (width/4, height/4), width width/2, height height/4
// Function to draw a Pokeball
 /*   void drawPokeBall(int width, int height){
int radius2 = width / 13;
int offsetY = 1; // Offset from the middle in the y direction
   // Draw the black circle
  // Turn off pixels coincident with the pixelOffRadius
        myOLED.pixel(circleCenterX + x6, circleCenterY + y6, false); // Turn off the pixel
 // Draw the filled circle at the center
// Function to draw a triangle
    void drawTriangle(int width, int height) {
    myOLED.line(width / 4, 3 * height / 4, width / 2, height / 4); // First line
    myOLED.line(width / 2, height / 4, 3 * width / 4, 3 * height / 4); // Second line
    myOLED.line(3 * width / 4, 3 * height / 4, width / 4, 3 * height / 4); // Third line
// Function to draw a diamond shape
     void drawDiamond(int width, int height) {
     int centerX = width / 2;
     int centerY = height / 2;
     int halfDiag = 10; // Half of the diagonal length
    // Calculate corner points
     int topX = centerX;
     int topY = centerY - halfDiag;
     int bottomX = centerX;
     int bottomY = centerY + halfDiag;
      int leftX = centerX - halfDiag;
      int leftY = centerY;
     int rightX = centerX + halfDiag;
     int rightY = centerY;
  // Draw lines to form the diamond
    myOLED.line(topX, topY, leftX, leftY); // Top to left
    myOLED.line(topX, topY, rightX, rightY); // Top to right
    myOLED.line(bottomX, bottomY, leftX, leftY); // Bottom to left
    myOLED.line(bottomX, bottomY, rightX, rightY); // Bottom to right
// Function to draw a completely filled heart shape
  void drawFilledHeart(int width, int height) {
  // Fill the two circles for the lobes of the heart
    for (int y = -10; y <= 10; y++) {
    for (int x = -10; x <= 10; x++) {
    if (x*x + y*y <= 100) {
    myOLED.pixel(centerX - 10 + x, centerY - 10 + y);
    myOLED.pixel(centerX + 10 + x, centerY - 10 + y);
  // Fill the inverted V shape for the bottom part of the heart
    for (int y = 0; y <= 25; y++) {
    for (int x = -15 + y; x <= 15 - y; x++) {
    myOLED.pixel(centerX + x, centerY + y);
  // Fill the small gap between the circles and the triangle
   for (int y = -10; y <= 0; y++) {
  // Update the display
   myOLED.display();
// Function to draw a smile
     void drawSmile(int width, int height) {
    // Draw eyes
     int eyeRadius = 4;
     int leftEyeX = width / 2 - 5;
     int rightEyeX = width / 2 + 5;
     int eyeY = height / 2 - 5;
      myOLED.circle(leftEyeX, eyeY, eyeRadius);
      myOLED.circle(rightEyeX, eyeY, eyeRadius);
    // Draw mouth
      int mouthRadius = 8;
      int mouthX = width / 2;
      int mouthY = height / 2 + 2;
      for (int i = 0; i <= 180; i++) {
       int x = mouthX + mouthRadius * cos(i * PI / 180.0);
       int y = mouthY + mouthRadius * sin(i * PI / 180.0);
      myOLED.pixel(x, y);
  //Loop contains actions for the game
  // Read the state of the mercury switch
     int switchState = digitalRead(mercurySwitchPin);
    // Check if the switch is on (HIGH)
    if (switchState == HIGH) {
       Mercury = 1;
     Mercury = 0;
    // Print the state to the serial monitor (optional)
    //Serial.println(Mercury);
  // Update keypad states
    keypad1.updateFIFO();
    keypad2.updateFIFO();
  // Read button presses
   char button1 = keypad1.getButton();
    char button2 = keypad2.getButton();
  // Game state logic
   switch (currentState) {
    case WAIT_FOR_START:
  // Show start message once
    if (!startMessageShown) {
    lcd.println("Press # to start.");
    Serial.println("Press # to start the game.");
   startMessageShown = true;
  // Start the game when # is pressed
    if (button2 == '#') {
    currentState = IN_GAME;
    finalString = "";
    index = generateRandomIndex(arraySize);
    currentWord = words[index];
    Serial.println("Game started, you must match with the word " + currentWord + ". Begin typing.");
    lcd.clear();
    lcd.println("Spell The Image!");
   myOLED.display();
  // Word to OLED picture
    if (currentWord == "rectangle") {
   drawRectangle(width, height);
   } else if (currentWord == "circle") {
   drawCircle(width, height);
   } else if (currentWord == "square") {
   drawSquare(width, height);
   } else if (currentWord == "triangle") {
    drawTriangle(width, height);
    } else if (currentWord == "smile") {
   drawSmile(width, height);
   } else if (currentWord == "diamond") {
   drawDiamond(width, height);
   }else if (currentWord == "heart") {
    drawFilledHeart(width, height);
   } else if (currentWord == "pokeball") {
    drawPokeBall(width, height);
   //myOLED.erase(); // Clear the display
   myOLED.display();
  // Handle keypad 1 input
    case IN_GAME:
    if (button1 != 0) {
    int row = (button1 - '1') / 3;
    int col = (button1 - '1') % 3;
    if (button1 >= '1' && button1 <= '9') {
    finalString += keypad1Mapping[row][col];
   } else if (button1 == '0') {
   finalString += keypad1Mapping[3][1]; // 'j'
   } else if (button1 == '*') {
   if (finalString.length() > 0) {
   finalString.remove(finalString.length() - 1);
   } else if (button1 == '#') {
   finalString += keypad1Mapping[3][2]; // 'k'
   Serial.println(finalString);
  lcd.clear();
    lcd.println(finalString);
  // Handle keypad 2 input
   if (button2 != 0) {
   if (button2 >= '1' and button2 <= '9') {
   finalString += char('l' + (button2 - '1'));
   } else if (button2 == '0') {
   finalString += 'v';
   } else if (button2 == '*') {
   finalString += 'u';
   } else if (button2 == '#') {
   Serial.println("Submitted: " + finalString);
   if (finalString == currentWord) {
   Serial.println("Correct! Press # to play again.");
   lcd.clear();
   lcd.println("Correct, (#)");
   currentState = WAIT_FOR_RESTART;
   Serial.println("Incorrect word. Try again.");
   lcd.clear();
   lcd.println("Incorrect. Try again!");
   finalString = "";
   lcd.clear();
   myOLED.erase();
  // Restart the game when # is pressed
    case WAIT_FOR_RESTART:
    if (button2 == '#'); // if (Mercury = 1)
    finalString = "";
    myOLED.display();
  //The if statements below link the 'random work' to a image displayed on the OLED
    }else if (currentWord == "diamond") {
    myOLED.display();
  delay(100);
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
That won't win you any friends here I am afraid. What do you mean when you say that it destroyed your image ?
How much of the code do you know works by testing it separately before incorporating it into the full sketch ?
Sorry!
Almost all the code works except the LCD for start new question, it works up until you answer, however once answered the lcd shows nothing.
as for the other question, I mean chatgpt changed it every time I ask it to fix the image, it makes it into an odd arrangement of circles such as a donut shape or everything but the center, etc.
heres an image of the pokeball's supposed to be image:
